Old 08-26-2004, 10:47 PM
98whitegpgt 98whitegpgt is offline
Send a message via AIM to 98whitegpgt
urathane bushings
anyone know where i can get a good set of urathane bushings for the gp suspention parts, i found one on bmr site, but that was it and the whole set was like 150 or somthing like that
Old 08-27-2004, 10:56 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: urathane bushings
Check GFWC or PFYC, I don't know if they can help or not but usually have a lot of GP upgrade Parts.
Old 08-27-2004, 11:08 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
That's about the going rate, but know the trade offs before you install them. Urethane bushings will tighten up your suspension, but they are also prone to squeaking, which in a daily driver can make you nuts if you don't really need the suspension stiffness they provide.
Old 08-27-2004, 02:39 PM
carnutcass's Avatar
carnutcass carnutcass is offline
AutoStoned sells the urathane bushings and replacement end links for the front......and they're inexpensive. Like richtazz said, corniering will be tighter. The squeaking can be eliminated by lubricating the bushing regularly with a good bushing lube. One example is http://www.pfyc.com/store/merchant.m...ct_Code=GN4016
Old 08-27-2004, 11:22 PM
a guy at the track tonight told me that if i put urathane motor mounts on i will get the most out of my shift kit. meaning that i will get more torque to the wheeles that is lost in the motor twisting is this true?
Old 08-28-2004, 01:06 AM
GTPCatz GTPCatz is offline
Banned
Re: Re: urathane bushings
Yes it is true
Old 08-28-2004, 06:41 PM
ok couple more questions 1st carnutcass what is autostoned? is that just like autozone?? i know kinda a dumb question. next is intense has the rear motor mounts and the front motor mounts, but zzp has just the front motor mounts, do i need the rear to keep the engine from rocking, or will just the front ones be good enough?
Old 08-28-2004, 09:19 PM
Banned
Front ones will be good enough...I think if you replace both you will get a strong vibration in the car....the car will vibrate quite a bit more with just the front
Autostoned = AutoZone
Carnutcass = CrAzEy
Old 09-03-2004, 12:27 PM
well i got some urathane front sway bar mounts and end links, they improve a little bit, but not much
