Still have some stuff for sale....
I still have some stuff here I can sell. Make me some offers:
body Stock Orange corner lights interior 93-97 Camaro DASH PLASTIC, The part that goes around the guage cluster. I already started sanding this smooth and it has some primer on it 93-97 Camaro DASH PLASTIC, The radio Bezel. chassis LT1 motor mounts (Including the stands on the K member) LT1 K member with Lower A arms (perfect for the LT1 swap into a V6 car!) LT1 Rack and pinion LT1 Block (standard Bore) with Timing cover and Crank Stock front and rear swaybars 1993 Formula Wheels Stock PHB engine Rods (pistons are attached) Crank Hub Harmonic Balancer/dampner LT1 Flexplate LT1 Intake Sensors from Intake Throttle body, missing Lower Assembly EGR Tubes (parts from the manifolds with check valves) Exhaust manifolds (2 sets from 94-95) Pushrods (Set of 1994, and set of 1995) Water pumps (1 complete, the other is a housing with impeller still inside) Couple sets of valve covers with filler tubes Front assy bracket Front A.I.R. Pump bracket lifters Oil pan Fuel Injectors (Stock) the Piece that goes in the Dis shaft hole to the Oil pump THe splined piece that goes to the opti I also have a slew of tires! I have: 4 Dunlop SP 8000's. they are worn down past the wear bars. 245/50-15 2 Kuhmo Ecsta, worn close to bare on one corner of each. 245/50-16 1 Akuret Ultra HP, almost new! 275/40-17 As far as engine parts, I no longer have the Heads, EGR Tube from Exhaust manifold, fuel rails, ignition module/coil, and opti. I should have almost everything else though. Just ask!
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100 1967 Chevrolet Impala (Sold) 1972 Chevrolet Chevelle (Sold) 1972 BMW R60/5 (Sold) 1980 Harley Davidson FLH 1987 Harley Davidson XLH 1992 Astro EXT AWD 1992 Chevrolet Cavalier 2000 Monte Carlo SS Pace Car 1087/3222 (Sold) 2001 Pontiac Sunfire 2002 Trailblazer LTZ (Sold) South Carolina F and Y Bodies www.SCFYB.com |
Re: Still have some stuff for sale....
how much for the intake and throtle body
Just for the Stroke of it... |
$120 (*plus shipping, probably $25) for the intake and TB.
Sorry for the late response, I just got back in town.
seriously, whos going to buy tires worn past the wear bars lol, just throw them out.
Re: Re: Still have some stuff for sale....
