Old 08-26-2004, 07:54 PM
jason322 jason322 is offline
Just Wanting Your Expert Opinions.
When I accelerate really hard a light comes on the looks like a box with some fluid in the bottom and a down arrow. Also my cars temp gauge slowly rises if I sit in line for a long time. Like I was trying to go to the movies and the line was going really slow and the temp was going up. Didn't get to red. The second I got through the line and speed up my temp went to normal.
I'm thinking low coolant. However it looks like my coolant is above the line on the container.
Old 08-26-2004, 08:19 PM
Sight N Sound's Avatar
Sight N Sound Sight N Sound is offline
Re: Just Wanting Your Expert Opinions.
That sounds like a coolant light. Open your radiator cap and see how full it is. You may have a clog in your resivor line and thats why none of it is coming out. Or its so dirty in your resivor it looks to be full but there is nothing in it........
Also what year car and is it a Z24. They are notroious for water pump failure between 45k and 70k miles
Old 08-26-2004, 08:21 PM
I checked the level and it looks to be good I could see the fluid and looked to be above low.
Old 08-26-2004, 08:26 PM
What about the year, Z24 or not and milage?
It sounds like it may have somthing to do with your waterpump.
Old 08-26-2004, 09:20 PM
Its a base model 97 104,000
How should I check the pump????
Old 08-26-2004, 09:59 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
its the head gasket, look for leaking coolant from the front right corner of the engine. Also make sure you check the coolant level when its cold, the coolant expands alot when it gets hot and will make it appear their is more than what their really is.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 08-26-2004, 10:23 PM
It still could also be the water pump.
If its not leaking out the head, check for thick white smoke or check your oil to see if there is coolant mixed in if so then it is the head gasket.
If none of that is happening its eaither a coolant level issue or the pump.
Old 08-26-2004, 11:04 PM
public's Avatar
public public is offline
1. Is your radiator fan coming on at the right time and temp?
2. Check your belt tension. Your water pump may be slipping.
Old 08-27-2004, 10:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the light you refer to is a low coolant light. Quad 4's are notorious for head leaks. They don't leak at the front like 2.2's, they crack between the valves. The water pump is a MAJOR job on these engines, not for the inexperienced, but is possibly the source of your coolant disappearance. The water pump is driven by the timing chain, so there's no chance it's a belt slipping. Good Luck
Old 08-27-2004, 11:36 AM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
your water pump is near the front of the car, and there is a hose coming from the radiator to it. its an easy fix. if you need detailed instructions on how to properly remove and install a new pump just hit me up.
Old 08-27-2004, 05:44 PM
I'll check the drive belt I installed a new altenator like last week.
Old 08-27-2004, 07:17 PM
public's Avatar
Good, improper belt routing or tension will cause the problem you describe. Always check the simple stuff first.
Old 08-27-2004, 08:09 PM
Piece of S***.
As I was waiting to turn left onto my street. I hear a horrible sound half way throught and the drivebelt broke. Like the edge of it toar off and it fell off the pulleys. (Didn't break in half.) Well after that I had the engine running for like 5 seconds before I got onto the street and turned it off. So do you think something else may have broken??? It was a very short time without the belt on the pulleys.
Old 08-28-2004, 03:26 PM
public's Avatar
No, you will be fine. Replace the belt. I think you may have found the cause of your temp problems. Make sure you route it correctly. Also be sure to inspect the tensioner. If the tensioner is stuck in place your new belt will not stay on.
P.S. I am not sure you can blame the car if you failed to notice the belt or tensioner was worn out :-)
