Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 08-26-2004, 07:36 PM
acmeman18 acmeman18 is offline
problem starting
when you stick the key in the ignition and turn it foward(as if to listen to the radio) all the lights come on just fine and everything is alright but the battery voltage meter is all the way down, and when you try and start the car it turnsover but it won't start. then if you turn it on and off over and over again the voltage meter will eventualy go back up out of nowhere and you can start the car. but the next time that you turn it off you have to go through the entire procedure over again. if you have any idea what the problem might be please let me know. thanks a lot.
Old 08-31-2004, 01:41 PM
msclcrmn msclcrmn is offline
Send a message via Yahoo to msclcrmn
Re: problem starting
sounds like burnt contacts in the ignition switch. The on and off cycles probably just contact a slightly different spot each allowing a good connection every now and then.
Old 09-23-2004, 12:51 PM
superdude529 superdude529 is offline
Angry Re: Re: problem starting
I bought my Bravada used one week ago and had this problem. I took it to the dealer and it was diagnosed as an ignition switch short requiring that the switch be replaced. It cost me $450.00.
Old 09-28-2004, 07:59 PM
duny duny is offline
i have the same problem, i get gas pumping out of the fule filter, every thing turns on. The engine sounds link it wants to start but it sound like it's not getting any gas. THere are sparks in the spark plug wires, but nothing. It all happened when i was driving and all of asudden the car just shut off. Can make heads or tails of it. Please respond before i kill my 98 bravada.
Old 10-07-2004, 05:22 PM
tcpip95 tcpip95 is offline
I too am having a similar problem with my 97 Bravada. I have 115k miles on it. It will crank but will not start unless I pour a small amount (less than half a cup) of gas into the carb. Once I do that it starts up and runs fine. I am getting just under 18 mpg with it. I've put in a can of carb/injector cleaner into the gas to see if that will help, but I've not gone through a full tank yet.
Any ideas? thanks.
