Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-26-2004, 06:41 PM
bsherman3 bsherman3 is offline
Steering
Does anyone else have a ton of play in the steering? Is there any way to fix it?
Old 08-27-2004, 08:13 AM
bawana bawana is offline
Re: Steering
what year--I have a ramcharger that has a coupler on the steering colume that is a real engineering marvel.when the pin gets worn there is all kinds of play in it.Had dealer change but problem came right back so I pulled it apart and found service tech change all but the pin thru colume and that was all shot.IT was a pain to remove. Had to heat with tourch and pound old one out.Must have been to much work for tech.
Old 08-30-2004, 08:55 PM
moparmike70 moparmike70 is offline
If it is a '93 or older Dodge just open up the summit catalogue and order the Borgeson steering shaft. Its a little pricey at $190 but it will solve the problem permenantly unlike the factory replacement coupler. It will just wear out in another year and 1/2. I did it on my 84 ramcharger and haven't had a problem since. The factory replacement is about $125 from the dealer.
