1998 accord stalling problem
hello everyone. i seem to have a stalling problem on my honda. when im out driving around or running errands. i will start my car up and it will die, i will start it up agian and then it runs just fine. this doent happen when its cold only when its at 0perating temperature. has anyone experience anything like this? i think its the main relay. i just recently gave it a tune-up also. it also died on the freeway this morning but in came to a stop and it started right up again without any problems. thanks for the help
Re: 1998 accord stalling problem
i think you're right, its a main relay.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB Electronics: Apexi VAFC (untunned) Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar. Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2 Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads |
Main relay replacement did not work for me.
I have a 1998 Honda Accord 4cylinder 4 door LX. Randomly the engine will shut off when slowing down. There is no specific weather or tempature it will happen more in. Its always when my foot is on the clutch and the tachometer falls to idle. Then there is a click and the engine is off. The only way I notice its off is if I am looking at the dash (it lights up) or I will find steering harder as power steering is gone. The engine does not go roughly or make any noise. Its just off. The lights and radio are un-interupted. Honda can not find the problem. The Honda Dealers have replaced the main relay, replaced the igniter, replaced the cars computer chip, checked the catalytic converter and found no problems. Air filter and spark plugs are new. They are stumped and I am left with a car that randomly stops working. Only other thing I can think of (that may not even be related) is that sometimes while cruising the car power, feels like you release the gas pedal, then apply it again. Like its backing off for half a second. Anybody have any ideas? |
Hi
I encountered similar problems with my accord a while ago..... The problem lies in the ignition switch for my case. The ignition switch was loose and the engine stalls by itself when in idle (Vibration is the heaviest in idle for most case) and when in cruise, it fine. maybe you might want to check out your ignition switch. Senseless Kidz |
