Old 08-26-2004, 04:26 PM
lucki17 lucki17 is offline
alphasonik any good?
does anybody know if alphasonik is any good? they have some subs that i want and they seem like they have good specs but i dont know a whole lot about audio so...
Old 08-26-2004, 06:23 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: alphasonik any good?
hit up Icixsound.com ... detailed thread on there
www.cloudcity.deviantart.com
Old 08-27-2004, 10:11 AM
enve enve is offline
I like alphasonik and think they are good
Old 08-27-2004, 03:43 PM
loismustdie loismustdie is offline
no, they're not
the aquabats are seriously the best band in the world
Old 08-27-2004, 04:26 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Correct me if I'm wrong but both alphasonik and swiss audio are owned by audiobahn= shit.
Old 08-27-2004, 05:38 PM
Haibane's Avatar
thing you are wrong on both parts there...
Old 08-27-2004, 06:12 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
they're ok for lower priced equipment
Old 08-28-2004, 12:56 AM
Swiss Audio
114 S. Berry Street
Brea, California 92821
Phone: 714-988-0380 • Fax: 714-988-0381
http://www.swissaudioinc.com/flash.html
Audiobahn
Audiobahn, Inc.
114 S. Berry St.
Brea, CA 92821
Phone: 714-988-0400
Fax: 714-988-0433
Alphasonik
Alphasonik, Inc.
114 S. Berry St.
Brea, CA 92821
(714) 988-0370 Phone
(714) 988-0371 Fax
PSW612
12” ALPHA 600 SERIES SUBWOOFER
Proprietary Cast Aluminum Alloy Machine Cut “Alpha” Basket
Proprietary Cooling Rings for Motor Assembly (Patent Pending)
Kevlar® Reinforced Composite Balanced & Laminated Cone
High Tensile Strength Two-Layer Surround for Enhanced Control
Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
75 oz. Double Stack Magnet
Rated at 700 Watts RMS
88dB Efficiency
Frequency Response of 30Hz to 500Hz
Dual 4 ohm 2 1/2” Voice Coils
8-Gauge Lug-Lock Input and Output Terminals (Patent Pending)
Mounting Dimensions — Depth: 164mm / 6 1/2”
Through Hole: 275mm / 10 7/8”
Diameter: 312mm / 12 5/16”
SPL1290
12” Ultra Excursion Woofer
Power Handling: 700 watts RMS
FATT 50mm / 1.97” Foam Surround
110oz Double Stack Strontium Magnets
Frequency Response: 22Hz - 500Hz
Efficiency: 93dB
Voice Coil: 75mm / 2.95” 4-layer ASV
Dual 4 Ohm, 2 Ohm, or 8 Ohm Capable
Hole Diameter - 275mm / 10.83”
Depth - 169mm / 6.65”
Features
Optimized for Maximum Sound Quality / SPL
PHAT 2” Foam Surround
80 oz. Magnet
Non-Pressed, Non-Transfer Paper Cone
KM3 Coated Cone for Low Cone Distortion
Bolt-Tight Cast Flame Basket
Multi-Connect Lug-Lock Terminals
Mounting Depth: 5 5/8”
Hole Cutout: 11 1/8”
Outer Diameter: 12 3/4”
Subwoofer Specifications
AW1200Q
Rec. Sealed Box Dims: 0.50 - 1.50 cu.ft.
Rec. Ported Box Dims: 1.30 - 3.70 cu.ft.
Free Air Usage: not recommended
Sensitivity: 92.7 dB
Frequency Response: 20-500 Hz
Recommended RMS Power: 700W
Peak Power Handling: 1400W
Impedance: dual 4 ohms
hrmmmm I think they are....also Alphsonik's top of the line series is abahn's ultra exursion series.
Old 08-28-2004, 02:47 AM
hmm okay, i was looking for a yes or no, but if they are owened by audiobahn then i dont think i want them, i was looking at the 12" that has 500rms and like 93 Db (sounds good to me)
Old 08-28-2004, 03:33 AM
engineer's Avatar
engineer engineer is offline
Banned
Send a message via Yahoo to engineer
93 ??? isnt that like... piss weak?
Old 08-28-2004, 11:22 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: alphasonik any good?
that's the efficiency
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
