Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-26-2004, 04:21 PM
canadagnguy canadagnguy is offline
too slow for money spent 14s?
i am new to this board and to computers in general but i was hoping you could help me with my gn i am having the same problem as the other guy . car profile( hooker exhaust with 2.5 inch downpipe gutted cat. 21lbs. boost ,30lbs. injectors,kn filter,i screen off maf sensor,fuel pump,reg and43lbs. pressure at idle vac. line off,and a reds aftermarket chip for 93 octane)and i do have a scan tool problem is i am not sure exactly what is most important to look at on the scan tool and what parameters are right or wrong it would be great to get an idea what i am looking at ive spent enough money for 12s i think. thanks
Old 08-27-2004, 07:59 AM
gnfreak's Avatar
gnfreak gnfreak is offline
boost seems pretty high for 93 octane unless you're using an alky setup.
i use the old turbolink and watch for O2 volts as well as degrees of knock. i need to run a fuel pressure gauge so i can see it at wot (need base setting plus 1 psi for each lbs of boost) in your case you need 43 + 21 = 63 lbs of fuel pressure. is your fuel pump hot wired? before the alky kit i was getting knock at 18 lbs of boost with straight 93 octane gas.
Keith LaCombe
Normal, Illinois
[email protected]
1986 Buick Grand National
1997 Chevy S-10 (daily driver)
2003 Chevy Trailblazer (wifes SUV)
1993 Chevy Camaro Z28 (kids car)
Old 08-27-2004, 01:45 PM
Re: too slow for money spent 14s?
i am not using the alky setup (alchohol inject. ?) and you are right about the boost it should be lower my mistake and i always put in 94 octane. The readings on the 02 volts should be in what range and how many degrees of knoch is acceptable (fuel pump not hot wired that is next) is the alcohol injection setup expensive ?hard to do? what kind of time improvements on average? thanks for the help
Old 08-28-2004, 12:20 AM
gnfreak's Avatar
i think o2 volts should not go below .760-.780 i believe (hipsi please chime in here cuz i'm going from my shaky memory) i'm thinking my alcohol injection is keeping this number hi for me, i really need to check my actual fuel pressure. lots of people tune for a very small degree of knock on the shift points but others say no knock is best. the alky kit was a SMC kit around $270 if i remember right (gotta work on this memory thing!) not cheap but what a rush it adds. there are other kits out there (Razor's kit comes to mind) as well as instrucions for a do it yourself kit. the first pull on alky with 22-23 lbs of boost really, really gets your blood flowing. check out the forums at t6p.com, turbobuick.com and last but not least turbobuicks.com. check out the alcohol forums for all you need to know. installation is a breeze but make sure you are in a tuning mood so you dont get carried away to start. i havent ever been to a track or on a dyno so i cant give you any numbers there. think i heard that every lb of boost is good for 10 hp???
maybe i'm hearing things as well. good luck
Keith LaCombe
Normal, Illinois
[email protected]
Old 08-28-2004, 07:30 AM
i was wondering if the alky kit is reliable and fairly consistent. It sounds to good to be true. i will check out those web sites. if the o2 readings are out alot should i just change the sensor? I wont be able to test for a while my electric brake motor is gone but i am writing this stuff down for when i do go out for a drive. thanks
Old 08-28-2004, 01:40 PM
gnfreak's Avatar
i'm sure hoping the alky kit is reliable!! if it doesnt spray when i'm at 20+ lbs of boost , then i'm going to learn how to change head gaskets (at the very least!!)
if your O2 volts are out of wack you need to figure out why. if they drop off when you are at WOT below the .780 or so then you need more fuel
i have a walbro 307 pump hotwired and know that some vendors sell the next step up (340) for about the same price. nice thing about adding alcohol is that it acts as extra fuel. it does seem too good to be true.
i also added a heated O2 sensor awhile back. probably could just of put in a new non-heated one lots cheaper. i think you need to check your O2 cross checks on the scan tool to see if yours is getting lazy. it never hurts to put a new one on (same goes for plugs, wires, etc.) its all about the basics and the combination. i just try to mimic what others are succesfully doing and avoid others pitfalls (let them change the head gaskets)
Keith LaCombe
Normal, Illinois
[email protected]
Old 08-29-2004, 01:20 PM
happy i found this site and thanks for your help i will be on here once and a while but winter is coming and the car is away till next year so i dont want to spend money on accumulator and o2 sensors so they can go bad sitting around in the garage.thanks. ttyl.
Old 08-29-2004, 10:30 PM
gnfreak's Avatar
Re: Re: too slow for money spent 14s?
good luck when you do get around to it. its probably snowing in canada already anyway!! if you promise to keep your cold canadian air (alberta clipper = BRRRRR) up in canada this winter i'll come up there next summer and help you with your buick. LOL
Keith LaCombe
Normal, Illinois
[email protected]
Old 08-30-2004, 12:47 PM
just starting to build my igloo thanks for the help.lol.
