Old 08-26-2004, 03:22 PM
ViperLX ViperLX is offline
Sound System
Well I am doing everything over in this car and this is actually the first time I have ever done any work to a car. I am installing a head unit, speakers, and cd changer. This will all be going into a 92 Accord. The speakers are Infinity Reference 6000cs. The changer is kinda big because it is a 10 disc one. I have been able to install the heat unit and the dash kit no prob. I am still waiting on the speakers but how do I install this cd changer. I know it will work the head unit but I am not sure how to wire it.
Can anyone help me out?
Old 09-02-2004, 09:50 AM
phantastic1 phantastic1 is offline
Re: Sound System
did you buy this new or used??? if new it should have instructions. most cd changers are hooked up this way...the antenna from the car connects to the module (comes w/ cd changer), from the module there should be another antenna cable that runs back to your head unit. then there should be 1 or 2 cords that run to your changer from the module. you should be left w/ a couple of wires that needs to be spliced behind the head unit. this part the instructions should tell you which wire you would need to splice into for the cd changer(assuming you have the instructions). most cd changers i've seen have 3 wires (power, ground, and memory). you'll just have to distinguish which one is which and wire it up to the appropriate wires in your car.
Old 09-02-2004, 07:06 PM
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
A little off the subject, but let me tell you from personal experience that Infinity Reference speakers suck... about after a year or so they will begin to deteriorate and crumble into little white flakes of nothing! The sun beats the hell out of those things. And I have limo tint on my Accord. Should have went with the Kappa series or another speaker.. I would return them if you still can... trust me!
[img]
