Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-26-2004, 03:58 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Question May I ask why you retard timing on a Turbo Engine?
I just wanted to know the exact reason why timing should be retarded for a Turbo Car...
Ya, It's Turboed.
Old 08-26-2004, 08:27 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: May I ask why you retard timing on a Turbo Engine?
it depends on the air/fuel mixture, o2 temp, tps & knock, amungst other things. the retard will comensate for longer durations of combustion, its not a universal retard setting. you might need to retard of increase your fuel or timming at diffrent bands of the rpms. it all depends on what your log says.
DSM geek
Old 08-27-2004, 01:02 AM
hundahunta hundahunta is offline
to prevent detonation~!
Old 08-30-2004, 10:45 AM
WhiteLine Civic WhiteLine Civic is offline
Re: Re: May I ask why you retard timing on a Turbo Engine?
yup
Old 08-31-2004, 06:56 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
wanna worry less about detonation for your turbo setup, then buy this, and you'll have a peace of mind.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33553
you can make me offers before it ends
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-31-2004, 06:59 PM
jeffseby's Avatar
That Is a good frikin deal. Why are you quiting. I hate seeing people quit at there cars!
Ya, It's Turboed.
Old 08-31-2004, 07:15 PM
AF - Advisor
Going to be taking 22 units at school each quarter this whole year so i can graduate by summers end. no more time for cars. I dont want to quit. I just dont have time. maybe ill start up with something fresh after school and the army. i just want something to get me from point A to point B, and then maybe to point C then back to point A
Old 08-31-2004, 07:21 PM
jeffseby's Avatar
lol Don't forget to stop by Point B!
Thats to bad, the armed forces make you change your life (maybe, I don't know shit). but you get $$$ for sweating your ass off!
Ya, It's Turboed.
Old 08-31-2004, 07:47 PM
AF - Advisor
$2100 a month for someones who has a BA in the Army Military pay sucks A$$. I guess the benefits, allowances, and student loan repayments makes up for it. At least its a garuntee job after college.
If you want money dont join the military!
I had a Drill instructor tell me once,"If you want to kill and get paid for it, then this is the place."
Old 08-31-2004, 07:52 PM
jeffseby's Avatar
That has a nice ring to it
Ya, It's Turboed.
Old 09-09-2004, 06:19 AM
Cronic Cronic is offline
Send a message via AIM to Cronic
Retarding of the timing is just a way of preventing detonation if it's occuring. If it isn't don't do it, because it also delays the fireing process of the engine, which causes you to lose power.
Another way to prevent detonation, is to richen up the mixture, and run colder plugs. Also higher octane gas does wonders to prevent detonation. If you have a knock sensor (obd1 B series(not B18b), and obd2 D/B series), when the engine detects knock, or ping, it will automatiaclly retard the timing up to I believe 8 degrees? This isn't much, but it helps.
Nothing left but a force fed hamster...
Old 09-09-2004, 11:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
normally you disable your knock sensor and when you tune your car, you tune it so it doesnt knock, ususally you just use the knock sensor to tell you if your detenating so you can just pull timing or increase fuel as needed
Team Lonely Drivers
Old 09-11-2004, 03:07 AM
I wasn't aware you could read the stock knock sensor. I've never tuned my car's with it off. I perfer running higher octane, or adding fuel to retarding timing. However, that's just personal preference. The higher advance you can run with out knocking, the more power you get, and timing does a good deal to make horsepower.
Old 09-11-2004, 11:42 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
with all the liberal BS around today id just like to say Thank you, my grand father served and my father served...i have plans otherwise...my grandfather would like to see me join the Navy but i am planing on going to UCF and getting my degrees in engineering, graphic design, and business...but anyways...retarding the timing is a way to prevent knocking...knocking is predetonation and often results in torched pistons...i think the rule is 2-3 degrees for every 50-100HP added?...or you can drop your compression ratio, or rich up the fule mixture, or run higher octane with colder plugs....or in higher boost cases (over 1 atmosphere) a combination of the two....
Old 09-12-2004, 10:20 AM
if you got your af set and you limited to pump gas and it knocks, i wouldnt give it more fuel to get rid of the knock, i would pull more timing.
usually a conversative number is .75 degrees per psi, and then add timing and see when it begins to knock.
some guys say to put it at .5 and then subtract till it stops knocking but then your gonna be detenating and could ruin parts, better to be safe and start with no knock.
Team Lonely Drivers
