Old 08-26-2004, 02:08 PM
LT1MAN LT1MAN is offline
Banned
Talking What should I do next?
ok im in need of some suggestions here fellaz, i have on my M6 94 Z:
cold air intake w/a scoop undernieth the car
deleted silencer
hurst comp plus shifter
pace setter headers
heddman cat. converter
flowmaster 80 series
lt4 knock sensor module
what would you guys suggest i do next. should i go for more bolt-ons or should i go for getting some more of that to the ground, for instance stronger clutch, lightweight flywheel, driveshaft etc.
preash
Old 08-26-2004, 02:17 PM
NailZ69's Avatar
NailZ69 NailZ69 is offline
Send a message via AIM to NailZ69 Send a message via MSN to NailZ69 Send a message via Yahoo to NailZ69
Re: What should I do next?
get sum 80's nigguh
[]D [] []\/[] []D [] []\[]
"If you see my car on a trailer.....It's STOLEN~!"
Old 08-26-2004, 04:57 PM
twdz28 twdz28 is offline
deleted silencer
pace setter headers
preash
stock clutch is good, you do not have enough to burn it up yet, lightweight flywheel not a good idea, you will have problems with it, driveshaft sounds like a great idea LS1 Alum will work just fine...
best mod i ever did was a Globel West trac link... even if your car is stock you can feel a big gain in traction from this...
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 08-26-2004, 05:04 PM
JoeJoe231455 JoeJoe231455 is offline
Re: Re: What should I do next?
How about a crank underdrive pulley? Cheap easy horsepower.
2001 Pontiac Grand Prix GTP
1994 Pontiac Firebird Formula
1972 Pontiac GTO
Old 08-26-2004, 05:09 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
Re: Re: Re: What should I do next?
i heard they can mess up your engine
Old 09-02-2004, 11:38 AM
Banned
whatr you talkin bout nailz? 80s?
i can have a chromoly steel driveshaft built into my car for 100 bucks. are ls1 driveshafts aluminum? i didn't know that.
and what is Globel West trac link?
and what about stuff like subframe connectors, control arms and stuff like that. maybe i need to stiffen up the front to back weight transfer a little. im not too worried about the actual suspension because i just want my shit to go straight and go fast.
what should i do
Old 09-02-2004, 11:50 AM
http://www.globalwest.net/camaro93.htm#TRACLINK%20kits
Old 09-02-2004, 12:55 PM
Banned
a little expensive for the trac link eh? i dont got 600 bucks right now. im looking to spend about half that. i think i might check out a driveshaft.
Old 09-02-2004, 01:03 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
underdrive crank pulleys will only hurt your car if you have a large power draw (ie system). theyre are a cheap easy mod, but not a huge difference in power.
the chromoly driveshaft is great, if you have 1200 horsepower. i would suggest getting an aluminum from either aftermarket or from a junked LS1.
if you want your car to go fast and in a straight line you will have to beef up the suspension. im going to get most to all of my components from bmrfabrication. ive worked with them a little already and its been excellent so far.
finally, i would say that the best way to get more power to the ground would be the clutch. i dont know much about the borge-warner, but i know that a factory clutch and an aftermarket are like night and day when it comes to getting the car to move faster...
*Better power-to-weight ratio than a C6 corvette*
Old 09-02-2004, 01:58 PM
Banned
chevyracincamaro,
so you are sure an ls1 driveshaft will fit in an lt1 correct. are the automatic and the manual driveshafts interchangable?. what kind of suspension mods do you think i should go with first.
i also think a clutch and flywheel combination would help me out a lot, especially since im running the stock clutch with 130K on it. it will slip if i dont hit it pretty close to right. how much difference would there be between an aftermarket stage 1 clutch vs. a stage 2 or 3, im pretty sure id be ok with a stage 1. i heard aftermarket clutches were hard to drive, ie you have to give your leg a real workout to drive across town, whudda yall thank?
Old 09-02-2004, 04:08 PM
Banned
and i do have a system by the way, not to much just a single jl w3 15 hidden in the trunk with an alpine strapped to the spare tire. i could lose a lot of weight without that. i love my system though. i dont really wanna get rid of my spare tire either.
Old 09-02-2004, 11:12 PM
'97SLVRBullet's Avatar
'97SLVRBullet '97SLVRBullet is offline
Send a message via AIM to '97SLVRBullet
At this point, on your current budget, subframes and LCA's w/ the relocation brackets would help you out. But I agree w/ T... you can knock off some time on your slip w/ a track link.
97 Z28
C.A.I. Edelbrock shorties,all free mods,Borla's,MSD,LT4 timingchain, 1.6r/r,LT4 cam, NGK,p&p heads,ported maf ,52mmTB adj fuelpressure reg.,373's,pcm tune by pcmforless, all poly bushings,spohn t/a, s/t brace, etc. What I don't have..no egr no air pump and no cats
Well dip me in chocolate and
throw me to the lesbians!!!!!
