Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-26-2004, 11:07 AM
mkingan mkingan is offline
Question Clutch help! New one?
I have a 1993 jeep wrangler Y/J. Its the 2.5 4Clyn. I notice a squeak when I start up in the morning but that's not the major problem. After running a little bit and coming to a stop. its very hard to get it to go into first. I also get a shudder coming to a stop (clutch in) if I am in say 2nd. I think the clutch is about had it but want to get an opinion before I start tearing apart. It shifts great 2-5th but you can't get it into first while rolling at all and at a standstill its a back and forth game till it goes. any ideas? thanks
Old 08-26-2004, 05:27 PM
gtmud gtmud is offline
Re: Clutch help! New one?
Sounds like your pressure plate is not disengaging completly. May be a broken lever. Either way you will have to pull the tranny to find out. How is it with the engine off?(going into 1st) Remove your starter and look inside, see if you see any metal shavings.
Old 08-29-2004, 02:10 PM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
how many miles are on the clutch/pressure plates??? The shuttering problem sounds like the fly wheel. When you put a new on in you need to get it surfaced by a local machine shop so it will grab clean again. As far as the other part, it could be a combination of things. Does the throwout bearing make any noises/squeak, etc... Your problem could be as simple as adjusting the tension on the clutch itself...
Old 08-29-2004, 03:00 PM
xj31 xj31 is offline
did you check the fluid in the clutch master cylinder?the slave cylinder is probably leaking.sounds like you probably need a clutch.replace the slave cylinder whether its leaking or not
