Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-26-2004, 09:08 AM
dlmerlin dlmerlin is offline
Question 94 SL2 Transmission
About half the time when I start from a stop the 1st gear in my auto transmission doesn't work and it starts in 2nd gear and after 50 feet I hear and feel a CLANK, after which it drives ok but I just don't have 1st gear. The other half of the time 1st gear is there and everything is fine. Obviously its a serious transmission problem. I had the transmission serviced but that didn't help. Any thoughts or advice? How long I can expect it to last? I have 212K miles so I can't imagine it is worth replacing?
Old 08-27-2004, 12:12 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 94 SL2 Transmission
any 'slamming' into reverse or drive?
i don't know much of autos. i do know a common failure of saturn autos is the input shaft nut becoming loose( one cause is shifting in to drive from reverse while still rolling back). slamming into gear is a sign of this, but i have never of completey loosing frist gear. you should ask on the forum at saturnfans.com
Old 08-27-2004, 08:22 AM
no slamming as you describe - only related to first/second gear
i'll check the site your reference
thanks
Old 08-28-2004, 08:29 PM
Jed Rule Jed Rule is offline
Had my SL start out in 2nd only when hot and lost reverse also. Needed a rebuilt transmission valve body. $600 parts and labor. I'm usually pretty good at repairs but I was afraid to do this. A new unit was $600 from Saturn plus labor.
