Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 08-26-2004, 05:58 AM
ee004 ee004 is offline
Fuel meter goes crazy
1994 Chrysler New Yorker/LHS, fuel meter sometimes goes up and down (and the yellow lamp goes on too) a few seconds, than itīs normal again.
Old 09-04-2004, 02:54 AM
AWP9521 AWP9521 is offline
Re: Fuel meter goes crazy
My 94 LHS does that too, I haven't had a chance to see if it's a wiring problem or if the Fuel Level Sender is going bad, but i'm banking on the sender as sometimes as the fuel level goes down the guage doesn't work at all then works again as the fuel gets used up, At least it will register the last 1/4 of a tank so I don't run out of gas. The downside is to replace the sender you also have to replace the fuel Pump as they are a unit assembly. The upside (Yes there actually is one!) is that the Gas Tank does not have to be removed or drained to replace it, There is an access panel under the floor mat in the trunk area behind the rear seat that you can remove to gain access to the top of the Fuel Tank to replace the Fuel Pump assembly, wish they all were like that! This also applies to Concordes, New Yorkers, Intrepids, and Eagle Visions, not sure about the 300M though. Also remember, relieve the pressure in the Fuel System before servicing or you WILL get a gasoline bath! also NO SMOKING!
Old 02-05-2005, 07:24 PM
bellaggio1770 bellaggio1770 is offline
Identical problem with my 1999 LHS...but as long as it goes up to its normal position it can do whatever it wants !
