Old 08-26-2004, 01:00 AM
joemathews's Avatar
joemathews joemathews is offline
No, it's not crankwalk!
http://members.rogers.com/shabster2/talon/crankwalk.wav
Here is a recording I just found of what crankwalk apparently sounds like. Thought it might be helpful for someone discerning between CW and lifter tick!
Kevin or other(s) please interject if you have had different experiences or sounds with engines dying of CW.
1996 Eagle Talon
Old 08-26-2004, 03:36 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: No, it's not crankwalk!
from the research i have done and the knowledge i have gained about CW is that there is no sound to it... and i have found a couple people calling it the "Silent Killer" cause you really dont know you have it until it is to far gone to save! unless you are constantly checking your main bearings...
Old 08-26-2004, 04:23 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
If that isn't CW than what is that sound? Bad fan blade hittin shroud? someone gettin their head put into a fan by the mafia? lol sorry....just popped into my head....just kinda sounded like when my daughter put her dolls head into a fan!!! lmao...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 08-27-2004, 05:10 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
when i had CW it didn't sound like that...just before my engine blew, i had a real loud ticking noise which was the trigger plate rubbing against the crank sensor.
Old 08-27-2004, 06:22 AM
kjewer1 kjewer1 is offline
AF - Advisor
That sound is presumably the crank sensor commiting suicide. I cant really remember what mine sounded like, but I did hear it for the last day or two it ran. You need some serious thrust play to wreck the sensor, .20 perhaps. Service limit is .009-.010
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-27-2004, 12:19 PM
MusGTang MusGTang is offline
Someone should answer there phone is what it seems to me. I have a gst and have drivin walked gst's and that aint crankwalk
Old 08-27-2004, 05:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
then what is crankwalk?? from my experiences with crankwalk and many other people agreeing with me, mitsubishi machined the cranks just a hair out of spec. so in turn, the crank wears out the center thrust bearing causing lots of movement in the crankshaft (lots of banging around which equals knocking) and after so much play it takes out the crank sensor and that's why the car suddenly shuts off. like joemathews said, "if metal is hitting metal, there will be a sound." correct me if i'm wrong but i'm sure there's alot of people that will agree with me.
95 Talon TSI AWD
97 Eclipse GST
