Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-25-2004, 09:01 PM
jmrev's Avatar
jmrev jmrev is offline
3S-GE engine swap on a 96 camry (5S-FE)
i didnt want to go on and read all of the post on the camry so here my question?
has anybody ever done an engine swap from a 5sfe to a 3sge on a 96 camry? if you have how much was the engine and labor for it? how long did it take? is it running well?..............i ask because me and my dad plan to get a more powerful engine and im thinking about a 3sge since they share the same engine family.
Old 08-25-2004, 09:14 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 3S-GE engine swap on a 96 camry (5S-FE)
Is it possible you can just swap the heads and timing belt, tensioner, pulleys, etc?
Old 08-25-2004, 10:07 PM
jmrev's Avatar
someone else told me that but i dont think i will be the same as if i do a complete swap.
Old 08-25-2004, 10:10 PM
Brian R.'s Avatar
Resident Chemist
I bet most of the difference between the two engines are in the heads.
Old 08-25-2004, 10:13 PM
jmrev's Avatar
will the horsepower increase if i do this? will it be the same as a if i were to get a 3sge?
Old 08-25-2004, 10:15 PM
jmrev's Avatar
Old 08-25-2004, 11:45 PM
Brian R.'s Avatar
Resident Chemist
Can't answer that. What you need to do is look at the crankshaft and piston part numbers in the two engines. If the crank is the same (stroke) and the pistons are the same (compression ratio and bore), then it probably will be the same. They are both "s" series blocks so the water passages, oil galleries, etc should be the same.
Followup:
Here are the numbers
3S-GE 210@7600 159@6400 86 (Bore) 86 (Stroke)
5S-FE 140@5800 142@4400 87 (Bore) 91 (Stroke)
They are different enough that all bets are off.
Old 08-27-2004, 08:35 AM
thewraith's Avatar
thewraith thewraith is offline
Send a message via AIM to thewraith
No you cannot do a head swap with a 96 5s-fe motor with the 3s-ge ..without major modification to the oil and water passeges...
to View photo album, use login and password below.
screen name:guestvisitor
password: pass
THEWraith Pics
WAIT FOR THE REBIRTH OF THEWRAITH... its coming
5S-GTE Project
Old 08-27-2004, 03:31 PM
Brian R.'s Avatar
Resident Chemist
Thanks for the clarification.
Old 08-28-2004, 12:16 AM
jmrev's Avatar
Re: Re: 3S-GE engine swap on a 96 camry (5S-FE)
SO DO I DO!
Old 08-28-2004, 12:18 AM
jmrev's Avatar
I FORGOT TO MENTION, MY FATHER HAS BEEN GETTIN REAL MAD AT LITTLE CARS LIKE COROLLAS ect. BECAUSE THEY GUN ON HIM AT THE STOP LIGHTS, HE SAYS THAT 140 HP? SUCKS FOR SUCH A HEAVY CAR!
Old 08-28-2004, 11:38 PM
jmrev's Avatar
can anybody please help me
Old 08-29-2004, 07:37 AM
thewraith's Avatar
email me and I can help you with some of your questions...
password: pass
THEWraith Pics
5S-GTE Project
Old 08-31-2004, 11:44 AM
jmrev's Avatar
and does anyone have an extra opinion
Old 08-31-2004, 11:49 AM
jmrev's Avatar
Re: Re: Re: 3S-GE engine swap on a 96 camry (5S-FE)
i would rather let everybody see this, that way they could know too.
