Old 08-25-2004, 08:26 PM
r8erz4life r8erz4life is offline
do subs still play when blown?
everything was normal then one day i turn my car on, turn up the volume to normal listening volume and my sub is making a funny noise, but it was not moving or creating bass. the music was still coming out though. i took out the sub and it looked fine, but it has a slight burning smell. the amp is still working (i think) and all the wires are fine.
the sub is a kicker cvr (500 rms) dual 2 ohm
the amp is a ca600 (450 rms bridged at 4 ohm)
theres no way the amp could have blown it right?
Old 08-25-2004, 09:02 PM
also the sub has 4 connector things (2 red, 2 black). i had one red connected to the - and one black connected to the +. the other two werent connected to anything. im wondering if this is the problem and that i was putting all 450 watts into 1 voice coil. no?
Old 08-25-2004, 11:01 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: do subs still play when blown?
Well with the way that you wired it, you could have easily blown both the sub and the amp. I don't mean to be rude, but what were you thinking wiring it up like that? Did you not consult any kind of info source when you were doing this?
You had one coil hooked up, this means your amp was seeing a 2ohm load when bridged (that is if you bridged it properly). This means, you could have possibly sent up to 900rms (this is before clipping btw, 1500+ if the amp was clipping completely, before it self destructed of course) to ONE voice coil (500rms sub, which means each voice coil can handle 250rms). So your amp was trying to play at 2ohm bridged, and your 250rms coil could have possibly seen 900+ rms.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-26-2004, 12:28 AM
Re: Re: do subs still play when blown?
no offense taken. i didnt connect them, but i wish i would have. there is 4 spots on the amp because its a 2 channel. to get it bridged you put the wires in the outside spots. so where would the other two connecters connect to? do you just connect the two to each other on the sub?
the funny thing is, that sub and amp lasted a long time and hit hella hard. thats one of the reasons i never bothered to worry about it. would it have been louder if both vc were connected?
Old 08-26-2004, 01:08 AM
sr20de4evr's Avatar
no, if the amp is bridged nothing is connected to the inside 2 terminals on the amp. As for the sub, the + on the amp should go to the + on voice coil A, then the - on voice coil A goes to the + on voice coil B, then the - on voice coil B goes to the - on the amp. This is called series wiring, if you want a better description, a quick google search should turn up several pictures that show you how to do it exactly. Who hooked everything up? I hope they didn't charge much
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-26-2004, 01:54 AM
my dad hooked it up. it was hooked up just like you said except it didn't have another speaker wire to hook up the + and - on the sub. i guess a 6 inch speaker wire was the difference. i think what happened is the amplifier kit only came with the 2 wires, so thats how he did it. i asked a guy at circuit city about the 2 unused connectors and he said as long as you have a ground, you will be fine. what a jerk
Old 08-26-2004, 08:01 AM
sr20de4evr's Avatar
the guy at circuit city actually told you that as long as you have a ground you don't need to hook up the second voice coil on a dual voice coil sub? Well that just goes to show why you never ask for advice at circuit city or best buy I guess, if they actually knew what they were talking about they wouldn't be working there in the first place
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-26-2004, 12:36 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
LMAO, Circuit city guys and Best buy guys are stupid... I was listening to the best buy guy helping a guy out. "hey you should really try these four way coaxials, the 3 extra speakers really push the highs and they also are 300 watts of power, now you can run it that high, but lots of people will only tell you to run it at the rms which is 75 watts..." and at about that point I stopped listening cause I was getting stupider by the minute
www.cloudcity.deviantart.com
Old 08-26-2004, 11:23 PM
yeah i really made a mistake talkin to one of those guys.
i have another question (might be stupid), but how do i test if my amp has a problem or something. it turns on and looks normal, but i dont trust it. i want to give it to a friend or perhaps sell it, but i dont want to be responsible for messing there systems up too.
Old 08-28-2004, 03:25 PM
this really is a serious question. i think im gonna keep it and get another sub, but i need to know how to check if it is working properly.
Old 08-28-2004, 05:45 PM
sr20de4evr's Avatar
do you have a multimeter?
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-28-2004, 05:58 PM
i dont know exactly what that is, but i bet my auto shop class at my school has one.
Old 08-29-2004, 02:06 AM
How would I use 1 or whatever?
Old 08-29-2004, 12:51 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
to test your amp connect it like you normally do, except do not connect any speaker wires to it.
put a meter on the speaker outputs. for your amp I'm thinking that you should get an output of about 10-15 volts per channel with your HU volume about halfway and your amplifiers gain at about halfway. If you're there then the problem my be that burnt smelling sub...
THE DARKNESS!!!
an African Soup Bone Production...
Old 08-29-2004, 06:55 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
I sence foul...a voltometer is basicly a direct short between two power sources....doing that will send the amp into protect mode and/or blow the fuse...the smarter thing to do is to leave the speaker hooked up and measure voltage from the (+) amp terminam to the (+) speaker terminal...and for 400 watts into a 4 ohm load this should be 100volts peak and about 50RMS with the gain all the way up and about half thoes figures w/ gain half way down...that burning smell was probably the voice coils wire's insulation burning...and yes you will have to replace the speaker...to find out how bad it is though get an ohmeter and measure DC resistance...find out what the factory says it is sapposed to be (remember DC resistance is much lower than Nominal Impeadence...most good speaker companies supply specs on both DC resistance and Nominal Impeadence) and if it is well below it the insulation is burnt but the copper its self isnt burt...yet...if it is much higher then factory specs then the copper has been burnt...
