Old 08-25-2004, 09:15 PM
riff22 riff22 is offline
bad o2?
can an o2 sensor go bad and still work, or do they just work or dont? my gauge says im lean all the time no matter what rpm im at im running like 15 psi all stock 2 gen talon. is this fine to drive? what should all be checked?
Old 08-26-2004, 12:31 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: bad o2?
check the gauge wiring
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-27-2004, 06:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: bad o2?
The sensor will fail gradually, not a good/no good type sensor They will start to get lazy, and always read on the low side. If its not cycling at idle and light cruise, it needs to be replaced. If it doesnt come up to the normal area at WOT, then it is pretty far gone. Does it come up even a little at Wide Open Throttle? IF it stays on the same LED the whole time, then I Would suspect the gauge or its wiring as mnetioned above.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-27-2004, 08:23 AM
Re: bad o2?
ok well im going to try a diffrent gauge tonight i know its wired corect. thanks
Old 08-28-2004, 04:35 AM
AF - Advisor
Re: bad o2?
Well lets not say that it may be wired "incorrectly," since it once worked and I'm sure you know what you are doing. I was refering more to a problem that may have come up, bad connection, etc.
Kevin Jewer
