Old 08-25-2004, 08:10 PM
CMedeirosJr CMedeirosJr is offline
Cool 93 S10 starter
i just got a 93 s10 from my grandfather for free, and it needs a new starter. i got it all unbolted but it wont drop down. what should i do?
Old 08-25-2004, 08:40 PM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
Re: 93 S10 starter
If you have it totally unbolted, you should just twist it, and drop it out. My starter in my 93 unbolts with 2 bolts going into the engine area, and then I have to unbolt the flywheel cover from the transmission. The flywheel bolts are the smaller 10mm bolts on the underside of the tranny. Two of them are easy to get to, the inner two are a pain in the neck.
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 08-26-2004, 05:07 PM
would i be able to take it out if i remove the front part of the exhaust?
Old 08-26-2004, 07:56 PM
skyhawk172 skyhawk172 is offline
is it binding on something. you will have to remove the flywheel cover, and is it 4 wheel drive? if so try loosening the front drive line. hope this helps. i dont think you should have to loosen the exhaust manifold.
Old 08-26-2004, 11:15 PM
STOVE BOLT STOVE BOLT is offline
Re: 93 S10 starter
AFTER UNBOLTING THE STARTER, LIFT IT UP AND MOVE IT TOWARD THE FRONT OF THE VEHICLE. LET THE BENDIX DRIVE GEAR END DOWN FIRST. IT SHOULD DROP RIGHT OUT.
HAVE FUN, AND ENJOY , " STOVEBOLT"
Old 09-04-2004, 03:14 AM
89s10pu 89s10pu is offline
Re: 93 S10 starter
What engine does it have? If it's a 4.3 then it should come right out. However if it is a 2.8 then you are in for some fun, like removing the solenoid and the wheel well!!!
Old 09-04-2004, 06:22 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 93 S10 starter
Be patient and wedge it out.
It will get out.
