Old 08-25-2004, 05:59 PM
BlindSix BlindSix is offline
2000 S-10 Enging Problems
I hope someone can help me out.
Recently, I have not been able to start my truck. Everything has operated normally and oil has been changed recently. The truck will turn over but it won't start. Any suggestions?
I have already tested the battery and it is normal. What else should I look at without having to take it to a shop?
Thanks!
Dustin
Old 08-26-2004, 02:07 PM
CW_racefan CW_racefan is offline
Re: 2000 S-10 Enging Problems
Can you hear the fuel pump running? You should hear it whine right after you turn the key on as it pressurizes the fuel system. Even if it is running, check the fuel pressure, the pump could still be weak. If that's ok, its something ignition related. Tons of things it could be there, VATS system problem, short, ECM problem, etc.
Good luck!
Old 08-26-2004, 02:38 PM
Re:
Well, here's what I've come up with so far:
The fuel pump is working but I haven't checked the fuel pressure yet. I have used starter fluid and the engine fires that way but it's not getting any fuel. I am wondering if it could be something as little as the fuel filter...but I don't know much about this stuff.
Also, a friend told me that there is a mesh sock-like thing inside the fuel tank that could possibly get clogged and not allow fuel through. What do you think?
Old 08-26-2004, 04:29 PM
Always start simple. If it hasn't been replaced before, try the filter first. Easy and cheap to do, but you will need to make sure there is no pressure on the fuel system, and may need a special tool to release the line from the filter (don't remember in this one). If you're not familiar with things, the best suggestion is to pick up a good shop manual if you think you will be doing work on it yourself in the future. Unfortunately the best manuals (Helms) are kinda pricey, but a Chiltons manual will get you through the basics.
Old 08-26-2004, 04:40 PM
83XFIRE 83XFIRE is offline
Send a message via AIM to 83XFIRE
If you figure it out, be sure to tell us. I have the same prob with my 88 ranger. Fuel pumps workin, wants ta start with starting fluid, gas gettin in motor, but no go.
98 Chevy Zr2
00 Yami R6
Old 08-26-2004, 08:01 PM
skyhawk172 skyhawk172 is offline
ifs its just turning over, does it have any spark, it not, check all your fuses, about the computers on the pickup i have no idea about.
Old 09-24-2004, 05:05 PM
bertman_7 bertman_7 is offline
blazer won't start
If your blazer has a fuse panel under the hood. I know how to fix it.there is a red connector block. the contacts are loose or corroded.
Old 09-24-2004, 05:11 PM
Re: blazer won't start
Flip the fuse panel upside down then turn the key on. wiggle the wires atached to the red block and you'll hear your pump turn on.
