Old 08-25-2004, 05:37 PM
vehicular_homicide vehicular_homicide is offline
Remove 92 Cavalier Front Door
What is the easiest way to remove the front door on a 92 four door cavalier. I noticed the hinges were bolted to the frame butone bolt comes from the inside out. I also noticed the pins on the hinges but i dont want to take that out if the spring on the bottom will be to hard tro compress when i put it back on. Any help would be appreciated.
Old 08-25-2004, 09:40 PM
Appleton Appleton is offline
Re: Remove 92 Cavalier Front Door
I replaced the pins on my drivers side door and you are right about the spring. It was a serious pain in the ass putting it back in. taking the pins out is seriously the only way your going to get the door off sucessfully, just make sure that you have someone there to help you hold the door when you're doing it. I believe there is a tool for compressing the spring so check into it before you go taking it off. I wouldn't really recommend taking the hinges off though.
