Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 08-25-2004, 04:14 PM
fc3sdrift fc3sdrift is offline
boost?
i have a couple questions
1. how much boost does a stock 13 bt put out
2. how much boost can a stock internal 13 bt hold
dont dirive it unless its sideways
1991 mazda rx-7
all stock
future plans for 13 bt
hks clutch and apexi turbo kit
jaja
Old 08-25-2004, 11:02 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: boost?
8-10 I think is the stock boost, but I don't know for sure.. I'd say 12-13 is the max but again I'm not positive
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 08-26-2004, 03:20 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: boost?
lol! Ive managed 15 on my stocker!
1988 10th AE Edition TII
More mods then you have.
Old 08-27-2004, 03:01 PM
FCsilvia's Avatar
FCsilvia FCsilvia is offline
Re: boost?
stock boost is 6.7 psi i believe.
depending on your mods, you'll range from 10-12 without a piggyback.
I've only went to 18 psi on a stock S4 motor. I think anything after that, you'll have to get the dowel pins reinforced.
-1987 Mazda FC3S TII - dynoed 316rwhp 06.28.04
S5/S6 SP motor w/ HKA T04R @ 14psi
CP Racing 4point Roll Bar
Cusco ZeroII Coilovers
SSR Watanbes RS-8 17x8F:17x9R
- 1993 Mazda FD3S Competition Yellow Mica R1
- 1991 Mitsubishi Galant VR4 - daily grind
JDM EVO RS motor w/ EVOIII 16G turbo
Old 08-29-2004, 01:01 AM
Re: boost?
thank all i appreciate the help
1991 mazda rx-7
all stock
jaja
Old 09-02-2004, 08:57 PM
rotaryismychoice rotaryismychoice is offline
Send a message via AIM to rotaryismychoice
Re: Re: boost?
no. reinforce your pins after 500. if the work is well done on the motor you shouldn't have any problems.
Old 09-02-2004, 09:21 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Re: boost?
18psi on an s4 turbo? I say BS; that would blow the turbo and the motor...
Old 09-06-2004, 11:05 AM
WankelTII WankelTII is offline
NO, with correct engine management, a stock engine can handle 25psi or even more, but it cannot run lean! That means you need higher octane fuel for anything over 15 to 18psi, depending on your set up. The s4 engine can handle more boost than most, it has lower compression. ALL TII engines are limited to between 500 and 600hp because of the weak dowel pins.
ON STOCK INJECTORS AND ECU
I would limit yourself to 10psi, the stock ecu sucks!!! With the stock ecu, hyperground wires, an apexi SAFC, and 720cc injectors in the primary and secondary spots, and everything tuned correctly, i still would not run more than 14 to 15 psi with the stock turbo. With a larger turbo, i would stick to about 13 or 14 psi depending on the size of the compressor wheel. (surges come faster with larger turbos) With stock ecu it is very difficult to get anything more than about 300hp without ending up with a blown engine.
