Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 08-25-2004, 08:44 AM
sharob5 sharob5 is offline
Send a message via MSN to sharob5
Unhappy prism died while driving
93 prism LSi, 124k miles, the car died on me while driving and it would not start again. I ended up having it towed home. The starter turns over the horn and lights and everything works it just will not crank. Can anyone offer any advice?
Old 08-30-2004, 10:35 PM
The Russian Kid The Russian Kid is offline
Send a message via AIM to The Russian Kid
Re: prism died while driving
How to Troubleshoot a Car That Won't Start
When your car won't start, you can easily check quite a few things before calling a tow truck. Use this simple chart to diagnose what might be wrong and what you can do to get back on the road again.
Engine won't crank
Steps:
1. Generally caused by either a dead battery or a bad starter, although you should check steps 1 through 5 to make sure it's not an operator error.
2. If car is automatic, check that transmission is in park and your foot is on brake.
3. If car is stick shift, check that clutch pedal is fully depressed. Check neutral safety switch behind clutch pedal (small button that prevents engine from starting when transmission is in gear). If clutch pedal doesn't fully engage neutral safety switch, engine will not crank.
4. Check that driver's seat belt is fastened (some cars will not start with seat belt unlatched).
5. Make sure you've properly inserted key. Turn it to On position and give steering wheel quarter turn in either direction.
6. Make sure alarm system is not activated, preventing car from starting (see owner's manual for car alarm).
7. Check for dead battery. Test wipers, radio, headlights and heater fan. If all work normally, battery is probably charged and you may have bad starter. If they don't work, move on to next step.
8. Check connection at battery and at starter (see steps 8 and 9). If battery connections are good and all accessories work, consider jumpstarting car (see How to Start a Car With Jumper Cables).
9. Open hood and check battery connections at terminals. If either connector is loose enough to move, problem may be bad connection. Jiggle or tighten cable end. Corrosion at battery terminal will also prevent car from starting. Clean terminal with wire brush or water and rag and tighten battery cable connectors.
10. Check connection at starter. Follow battery cable from positive battery terminal to starter. Make sure connection isn't loose. Lightly tap outside of starter with hammer. Sometimes this will free stuck components inside so car can start.
11. Consider push-starting car (manual transmission only) if battery or starter is at fault (see How to Start a Stalled Car).
12. Call tow truck.
Engine cranks slowly
Steps:
1. Only one thing causes this condition: a battery that is not fully charged.
2. Open hood and check battery connections. If there is any movement at positive or negative battery terminal, car may not start. Jiggle or tighten cable connector. Corrosion at battery terminal will also prevent car from starting. Clean battery cable ends and battery terminal with wire brush or water and rag and tighten battery cable ends.
3. Check battery-acid level (only possible with some types of batteries). Use screwdriver to pop open small caps on top of battery. Add water until level reaches top of plastic split inside each battery cell (distilled recommended, but tap water will work).
4. Jump-start or push-start car.
5. Call tow truck.
Engine cranks but car won't start
Steps:
1. There are hundreds of possible reasons your car cranks but doesn't start. Here are a few quick items to check before calling a tow truck.
2. Turn key to On position and check gas gauge to make sure car's not out of gas.
3. Open hood and look for disconnected spark-plug wires or vacuum lines.
4. Check fuse box for blown fuses (see How to Fix a Faulty Car Fuse).
5. Call tow truck.
Engine runs but car won't go
Steps:
1. A problem with the transmission or the wheels puts your car in this state.
2. Release parking brake.
3. Make sure transmission is properly in gear. Put it into park and then back into gear.
4. Check ground outside car for objects blocking wheels.
5. On manual transmission cars, open hood and check fluid level in clutch master cylinder (see How to Add Brake Fluid to the Clutch Master Cylinder).
6. Check level of automatic-transmission fluid (see How to Check and Add Fluid to Your Automatic Transmission).
7. Call tow truck.
'We're the knights that say..."nee".'
Old 08-30-2004, 10:44 PM
If your car won't start due to a dead or low battery or a broken starter, you can push-start it in just a few minutes. Try the following methods to get it rolling again.
Steps:
1. Determine if your car has a dead battery or a bad starter. If the engine cranks (makes a rr-rr-rr sound), your problem lies elsewhere. If the engine is silent or you only hear clicks when you turn the key, then your battery or starter is probably bad, and a push-start may be just what you need.
2. If your car isn't on a hill, ask a couple of friends or passersby for help.
3. Turn the key to the On position.
4. Release the parking brake.
5. Push down on the clutch pedal and put the transmission in second gear.
6. Keeping the clutch pedal depressed, either shout to your friends to start pushing or let the car roll downhill.
7. When the car is rolling as fast as a person running, slowly release the clutch pedal while giving the engine a little gas with the accelerator pedal. The engine should start.
Overall Tips:
This method works only with a car that has a manual transmission (a clutch).
Overall Warnings:
The car may jump forward when you release the clutch. Make sure there are no people or obstructions in front of the car.
Old 09-14-2004, 01:11 PM
ricer86 ricer86 is offline
sounds like a fuel problem....(bad injectors,bad fuel filter) replace the fuel filter and if that does not work then measure the amps going to each injector....you need a special tool to do this so try to find someone with the tool.
Old 10-19-2004, 12:26 AM
stephiemullen stephiemullen is offline
I had a similar problem with my '95 Prizm. I was driving and in second gear, it misfired so I pulled over and the car just died. It would not start and it smelled of gasoline. I got help pushing the car and it ended up starting so I could get it into a parking lot. It was scoped and it was the distributor cap and rotor and the ignition coil.
Old 11-10-2005, 02:27 PM
myproblem myproblem is offline
This problem sounds like a broken timing belt. I have a 92 and that happened to it. Please let me know if I am right. I feel like you proably have gotten it fixed by now. Thanks! [email protected]
Old 11-12-2005, 02:16 PM
dgee dgee is offline
check your fuses .ignition coil fuse.
