Old 08-25-2004, 08:00 AM
Geno44 Geno44 is offline
88 Z24 Fan Belt Change
Im looking for an east way to change a fan belt on this car..Getting it off is no problem.. but I always have a heck of a time to get it back on..Is the some kind of tension adjustment on this car? Thanks
Old 08-26-2004, 01:25 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 88 Z24 Fan Belt Change
your car has a spring loaded belt tensioner. IT has a square hole cut in it that a 3/8" drive ratchet fits into. Follow your belt routing leaving the alternator until last, put the ratchet in the tensioner and pull up, loop the belt over the alternator and release the tensioner. done. NOTE- some of these cars are a tight fit, and you may have to use a flex handle or special serp belt tool if there isn't clearance between the frame and tensioner to get your ratchet in there. All cars have serp belts these days, you may want to invest in a Serp belt tool, makes the job much easier
