Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-24-2004, 11:17 PM
bobaroo7 bobaroo7 is offline
Flashing Seat Belt Light
I have an 1989 Camry V6 with a constantly fashing seat belt light.
How do I fix this problem?
Old 08-25-2004, 09:25 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Flashing Seat Belt Light
Does it happen even when you have the driver's side seat belt fastened? If so, the sensor inside the clasp may be bad, or there could possibly be a short in the connection to the clasp sensor. I had this problem, all I did was yank the bulb out...hadn't had any electrical problems since then.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 08-25-2004, 12:39 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
There could also be a problem with the passenger seat weight sensor. You may have something on the passenger's seat that is triggering the weight sensor. It may also be malfunctioning. It may be signaling that there is someone sitting in the passenger seat when there really isn't. Either of these would cause the same symptoms as what you are talking about.
Old 08-25-2004, 02:11 PM
Never knew there was a passenger weight sensor, but now that it's been brought to my attention there is, it is a likely cause of a the problem. Check the both out...let us know if you need any further help or if you get it figured out. Best of luck.
Old 08-25-2004, 06:47 PM
Brian R.'s Avatar
Resident Chemist
I don't know that there is either, but alot of cars have them. I am not familiar enough with '89 Camrys to know if some models had them or not. Tough to find out these details without going to the library...
Old 08-25-2004, 10:44 PM
All I know is that I've never heard of a Gen 4 with them, so I automatically assumed that the older ones didn't have them.
Old 08-25-2004, 11:56 PM
Brian R.'s Avatar
Resident Chemist
Accords have had them forever, as does my 4Runner.
Old 08-26-2004, 04:15 PM
I've heard of the 4Runners being equipped with them...never the Accords or Camrys.
Old 08-27-2004, 03:13 AM
Bossman Bossman is offline
I've had this exact problem with mine too. All I did was spray some electrical contact cleaner into the female end and...voila!!.....end of problem. Definitely cheap and worth a try.
