Old 08-24-2004, 10:29 PM
cyclonesisu2004 cyclonesisu2004 is offline
97 blazer misfiring cylinders
misfiring codes p0300 on cylinders 4 and 6, have codes from 10-40. fuel pump was changed and new spark plugs, plus fuel injectors tested ok, what else may cause this misfiring
Old 08-25-2004, 01:30 AM
OverBoardProject OverBoardProject is offline
Banned
Re: 97 blazer misfiring cylinders
Try - checking timing
- hook the timing light up to the misfiring plug leads, see if the light skips a beat.
- Taking off distributer cap, and cleaning all contacts, including router
- wiggle the distributer shaft... the bushings could be worn out
- If that doesn't work you might have to replace the distributer cap, or plug wires
Old 08-25-2004, 09:36 PM
Thanx for the reply. While replacing the distributer cap, should the router be replaced too to insure best performance or will cleaning do the job?
Old 08-28-2004, 01:13 AM
Banned
I would usually replace the router with the cap, however at the price that I'm sure a new router costs it's probably worth trying to clean it first. If it still acts up replace the router
Old 08-30-2004, 10:27 PM
97 blazer misfiring cylinders X2
final touch- ive replaced the distrib. cap, plug wires, fuel pump, spark plugs, fuel filter, and guess what........ same thing. so i did some research, and found that the fuel injectors are known to plug constanly, or may go out at an early age, so what im wondering is this true, and if so why dont more people know about it????
Old 09-02-2004, 12:32 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
first off, replace your rotor with the new cap ALWAYS.
Sounds like you need to replace both injectors going into 4 & 6 or have them ultrasonically cleaned.
