Old 08-24-2004, 09:29 PM
DavidM1980 DavidM1980 is offline
Send a message via MSN to DavidM1980
Need Help Honda_99.
I have a 98 Honda Accord EX V6 and the trans is leaking on the Drivers side right out of where the drive shaft connects to. I was told that i need a new trans. Is their any way arround this? Or what would you suggest that i do. Do you know if honda has any recalls on this. I have a friend that is a Master ASE Certified Tech and he was the one that told me the trans was shot and this is becomming a common problem.
Please HELP!!!
Thanks
DavidM1980
Old 08-24-2004, 10:00 PM
HONDA_99 HONDA_99 is offline
Re: Need Help Honda_99.
if its leaking at driveshaft and differential, you might need to replace oil seal. that doesn't require transmission removal, but you might have to shell out $200-$300 for that.
beside leak, how is transmission performing? any hard gear changes, any slippage?
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 08-24-2004, 10:25 PM
gitter44 gitter44 is offline
Sounds like a driveaxle oil seal leaking, very easy fix cost is about 10 bucks for the seal if you do it yourself.... If your trans hasn't been giving you problems other than leaking fluid I wouldn't even think about replacing it. If your friend told you you need a new trans just for a little leak...... I would look for a new friend.
