Old 08-24-2004, 08:57 PM
98frdrngr 98frdrngr is offline
knock sensor??(leaking coolant)
someone please help me i am having trouble with my 92 grand am. there is a small 90 degree elbow that comes out of the firewall that leaks coolant. everytime i fill it up it pours out. i did a simple diagnostic on it and it said the "knock sensor circuit". please help i dont know if these two things have something in common but i need the car for the weekend. please help me.
Old 08-25-2004, 11:11 AM
dlwdkh dlwdkh is offline
Re: knock sensor??(leaking coolant)
Your heater core is going bad! Go to your local major parts store and purchase a can of "Bars Leak" radiator stop leak. http://www.barsproducts.com/origin.html
Follow the directions and it will do you for a while. But eventually you will have to replace it. $200 to $300 job.
Old 08-25-2004, 10:27 PM
i looked on the autozone web site and they have heater cores for around 30 to 50 dollars. the removal and instalation cant be that bad. and what about the trouble shooting code about the "knock sensor circuit" thanks
Old 08-26-2004, 01:35 PM
i dont know anything about knock sensor ciruit.
I do know that that heater core is not real fun. If you want to be able to get to it you have to take out half the dash.
Old 08-26-2004, 02:09 PM
GASE 95 GASE 95 is offline
if its coming out of the firewall then its more than likely the heater core. I cant think of anything else that would be in that area that has fluid running to it (assuming that the leak is on the passenger side). It is possible to do it urself if you have the time and patience. But in the meantime i would buy the Bars Leak if you dont have time to do it before the weekend.
Old 08-28-2004, 01:45 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The knock sensor is an unrelated coincidence. The heater core is definitely the coolant loss, but it's not that hard. Remove the passenger seat so you can lay comfy, and it's a matter of 7 screws to get the cover off, and two heater hoses under the hood, (jack the car up and remove them from underneath-much easier). Finally, remove the two straps hoding the core in and it's out
