Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 08-24-2004, 08:28 PM
lovingames lovingames is offline
'87 Civic died, won't start
Hi there. I have an '87 Civic 4D, 80,000 miles, with a problem. While driving home the other day the car just quit running. Poof... going 45 the engine just died... no power. I still had lights, radio, the works. Pulled over and tried to start and all I got was a small whirring sound when I turned the key. Tried several times over a few days and same thing. I do have lights and radio... but no start. I can't afforad huge costs so I'll have to do the repairs myself. Any suggestions on where to begin?
Old 08-24-2004, 08:55 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: '87 Civic died, won't start
Check the battery voltage.
You may have a bad alternator which means that you could have been running on battery power until there just wasn't enough voltage to keep the motor running. If you have a bad alternator you will also have low voltage, you may have enough to turn the lights on, but not enough to start the motor.
This happened to me once. I was driving along with the heater, lights and wipers goin' then "poof"... nothing.
That's where I'd start.
Old 08-26-2004, 08:30 PM
Thanks for the start... I did check and there is poswer from the battery and I even tried to jumpstart it too but, still no engine sounds. I checked all the wiring and it looks sound, no cracks, melted places and all pluged in (hopefully in the right places). I'm still looking for a solution and will continue to check back in the event anyone else has ideas.
Thanks
Old 08-27-2004, 12:05 AM
lxndr's Avatar
AF -Advisor
Have you checked the main fuse box located under the hood by the passenger side strut?
Old 09-08-2004, 12:42 PM
cultra cultra is offline
I had a simular problem when i stopped at a stoplight. as i took off my car just all of a sudden died on me...i could turn the lights on and off and everything but no juice to turn my car over. when i got my car towed back home i checked everything and they all seemed fine. then i checked my timing belt and it was completely broken so you should check your timing belt.
Old 09-08-2004, 01:30 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
I was thinking the same thing... Your timing belt would control your cam gearing... But you would get more than just a whirring sound... Start with the timing belt, and see what else pops up...
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-08-2004, 07:37 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
if the timing belt is gone you will have bent valves
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 09-24-2004, 09:49 PM
Diskord Diskord is offline
Talking
My '90 CRX did that exact thing, driving along, then suddenly it just died. I still had full power; alternator problem would likely cause battery to be sucked nearly dry if it stops in mid drive. It was as simple as a new rotor, somehow the screw locking the rotor SNAPPED! So it was easily fixed with a new rotor (not the cheap brand; I think that was the root of the issue).
Hope this can help ya.
Old 09-24-2004, 11:17 PM
cvcc_wagon's Avatar
my bro had that with his 89 crx except the screw just came out a couple times. we put some loctight on it and it hasn't been a problem since
