Old 08-24-2004, 07:06 PM
dogman777 dogman777 is offline
Question Name that sqeak!
I have a little sqeak, kind of a chirp while driving. I don't hear anything when I jump up and down on the bumpers. Could this be the chassis? Are there lube points for the chassis? My initial thought was the shocks, but like I said, I can't get them to sqeak.
Old 09-29-2004, 11:20 PM
92EscrtPmp 92EscrtPmp is offline
Re: Name that sqeak!
if it's under the hood, check anything with a pulley. Most important, the water pump
Old 10-01-2004, 09:57 PM
Re: Re: Name that sqeak!
Thanks for the reply. It's something to do with the suspension for sure and seems to be coming from the rear. It doesn't change w/ engine speed, never does it while not rolling, and usually accompanies a bump in the road.
Old 10-01-2004, 10:32 PM
rubber bushings in the tierods, or stabilizer bars. mine was equipted with Tierods because it was wrecked before I got it, unfortunatly. But I had to replace it due to a minor accident, (better left unexplained) and the Junk yard couldn't get the replacement off the parts car because they were using heat around a rubber bushing in the tierod. after that my car always squeeked from that part of the car, swo check it to see if it is bad...
My Car eats Civic's for Breakfast,
Neon's for Lunch,
and Eclipse's for Dinner.
And it's a wore-out `92 Ford Escort LX Wagon!!!!
Old 10-02-2004, 07:06 PM
I was thinking a bushing too. I search for replacement parts, but I'm not sure what the suspension parts are even called. I don't have a repair manual, and I don't really want to buy one since I'm going to be selling this car in the next few months.
1. Tie Rod
2. Control Arm
3. Stabilizer
Am I right here?
Rear driver's side:
Old 10-03-2004, 01:50 AM
Just thought bout it, chirp while driving.... shocks don't squeek...
WHEEL BEARINGS!!!!!
it won't squeek when you jump on it, but when it first starts to go, it chirps, then it gets to a wha, then it sounds like your hitting bumps in the road when your not...
That's the problem...
Neon's for Lunch,
Old 10-05-2004, 10:03 PM
WHEEL BEARINGS!!!!!
So if I jack up my car and try and move the wheel back and forth to check for play, that should tell me if the bearings are bad. Is that right?
Was I right on my picture and the suspension parts?
Old 10-10-2004, 03:18 PM
Snow93 Snow93 is offline
Send a message via MSN to Snow93
when i replaced the struts and springs on my escort ended up getten a chirp while driving or ridding over rough road... but like 92escrtpmp said.. could be the bearings goin..
As far as checken for play is concerned if you get any movement(back and forth) then your bearings are shot, if youd ont get nothin from that try rotatin the wheel if it feels rough or there noise bearings are likely shot
