Old 08-24-2004, 06:06 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
i would like to raise my tacoma an inch and add some wide tires
will wide tires wear my steering box and front end out? i has winking maybe 17x8 wheels and raise it an inch or two.
Old 08-28-2004, 08:33 AM
Blazing Rice Blazing Rice is offline
Get some coil spacers, you can get maybe 1-2" out of those for cheap. You can run 17x8 wheels on your truck, make sure you get the correct backspacing though.
Old 08-29-2004, 09:52 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: i would like to raise my tacoma an inch and add some wide tires
Yep, what Blazing Rice said.
You may also want to consider a body lift as well.
With 8" wide wheels, don't get tires that are any wider than 12.5". And no, they won't be too hard on your steering box or anything else.
Old 09-08-2004, 03:47 AM
Z71sc's Avatar
Z71sc Z71sc is offline
Arrow Re: i would like to raise my tacoma an inch and add some wide tires
My education is in Aeronautical Science (Jets/Jet Helicopters) I also fly all of them, who had a toyota 4x4 v6 xcab for 250,000 miles............no problems with steering box, power steering, only cv's (which are plastic covers) after enormous miles.
2 inch is the minimum you can go and if your going to go that hight, the perfect tire SIZE tire would be a 32x11.5 it looks really good on your truck, good gas milage and you don't have to change the gearing. Stay with the following below, you'll have no problems
It's only about (1) more inch taller than stock and (1.) inch wider than stock, so it gives that sqauty look perfect look.
This is my 3rd 4x4 so, the mistakes have been all done with. How is it when you go around a corner, your entire truck "ROLLS". Underneath your stock truck your have a bar running underneath it called a "ANTI_SWAY BAR."
This bar can bee upgraded to a thicker one for about $150.00, i forget the name of the company. The installation of the thicker "ANTI-SWAY BAR will not affect the ride of the vehicle whatsover.........your truck will sill be smooth........it will resist rolling, that's all.
What else, any other questions PM me..........oh Sam's CLUB (competition to Costco) who is operated by SAM WALMART has a goodyear CALLED THE ADT2 which is sold to those stores and it is an awesome TIRE and very quiet, they just don't make it bigger than 31"
Then if you really have money and don't care........Dick Cepeck makes tires that are 31x12.50 yes you heard it right..........31x12.50 so your truck is just as fast as stock and just as wide as the big 33" tires.
I had them on my toyota 4x4 V6 xcab and everybody would stop me.
THose tires were equal to Peirelli (sp) in truck tires, they didn't slide in the rain, were so soft. they are now about $299.00 per tire or more.
SO anyway, send me a PM, let me know what you did with your truck. p.s, LUV those classic trans ams. What? 6.6L Burns more gas than a 747
Old 12-05-2004, 04:51 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
I disagree with goinbig , larger wider tires are harder on everything in the front end. This is why they sell fish plates for the full size blazers/jimmys. The exact wording in the parts book reads "Because it WILL break" meaning the frame right at the steering box. Especially wider tires, they are alot harder to turn becuase they have a wider foot print on the ground although this may not be as much of an issue on a lighter vehicle like a tacoma, my 88 jimmy was 5600 lbs.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 12-12-2004, 05:40 PM
Andydg Andydg is offline
Re: Re: i would like to raise my tacoma an inch and add some wide tires
It will wear most everything in the front end out, but over time. If you're going for tires that fit an 8" wide rim you won't have to worry about things wearing out for a while though.
If you plan on doing anything close to moderate off-roading please get a suspension lift, and if you still need a little more clearance then consider a body lift. The reason being that when you get a suspension lift you upgrade just about all the suspension components if not all and they're made to be beat to hell. A body lift will give you the ride heigh you're looking for but it will still have the stock suspension for off roading.
Old 12-12-2004, 10:52 PM
he only wanted to raise it an inch. Why spend the money for a 1" suspension lift?
I said he should get 12.5" wide tires. They will not cause the frame to crack, unless he is really rough on the truck.
Old 12-29-2004, 10:03 PM
danny350 danny350 is offline
Full-size, older chevy's had weak, flexible, frames that would crack near the steering box with big tires, Your truck doesn't.
The larger tires will wear your steering/suspension faster than stock tires will. How fast depends on how big you go and how you drive.
My friend has a 97' Tacoma, with a 6" Trailmaster susp, 3" body and 35's. His struts/tie-rod-ends/ball-joints don't last too long.
Old 01-02-2005, 01:31 PM
Big enough tires will cause any frame to crack near the steering box. Chevy's are just weaker in that area.
Old 02-07-2006, 07:23 PM
WiKiD_G's Avatar
WiKiD_G WiKiD_G is offline
Thumbs up Re: i would like to raise my tacoma an inch and add some wide tires
http://www.mytoyotatruck.com/gallery...Good/78330.jpg
Take a look at my lift. King Racing coil overs straight from box to truck in about 1/2 hour. Have 285/70/16's equivalent to 32.8" tires. Have to hop up to get in and I'm 5'9"
Old 02-09-2006, 07:43 AM
RootBreaker RootBreaker is offline
not a bad looking truck....
so here is the deal... if all he needs is 1" there are a few ways...
1. grab your sawzall and cut away
2. buy a body lift
3. buy a suspension lift
now doubt most of you will opt for #1
#2 will not and I repeat will not be tough on the steering box or components.. cmon guys.. he is only lifting the body off the frame 1"
3. can do but expensive.. if you are going to do that go crazy and lift that puppy..... 1" lift kit.... no bragging there...
now I suggest the body lift..
alot of people will say.. they are unsafe and horrible...
I have ALWAYS had a boy lift.. well not now as my truck had to come down to be NJ legal..but found a way around that so will be adding a body lift back on hopefully this summer...
1978 chevy 4x4
3" body lift
33x12x16.5 tires
wasnt big but wheeled it hard for YEARS
then came
12" suspension lift
3" body lift
40" hawgs
getting ready for rockwell axles
53" michelins
but back on NJ legal
6" suspension lift
1" zero rate
40" hawgs
doing a crew cab upgrade this summer...
gonna try and find a 10k+gvrw crew cab
then 3" body lift back on
12" leafs back under
rockwells under
53" michelins
LEGAL down the road
Old 03-09-2007, 12:48 AM
hgarza908 hgarza908 is offline
Quick question I have a 2004 Silverado 2wd and I have tires for it,but I don't know if they will fit without a lift. The Tires are 31x12.50. Do you know if I will need a lift and if so what size of lift?
Old 01-24-2010, 06:49 PM
Slulsetum Slulsetum is offline
Send a message via ICQ to Slulsetum
Download playstation 3 console games for free only at www.downloadps3games.org
Howdy
Play video games? want free ps3 games? today you can [url=http://www.downloadps3games.org]download playstation 3 games 4 free here
[url=http://www.downloadps3games.org]downloadps3games.org
