Old 08-24-2004, 04:56 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Lower ball joint
well today i went to remove lower ball joint on my SI to replace axle and i could not get the castle nut off the end of ball joint. i took cotter pin out and went to take castle nut off but the end ball joint threads would spin with nut as if they were one. any advice as to how to take nut off with out joint spinning as well?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 08-24-2004, 05:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Lower ball joint
my upper ones did that, just press it up into arm while your taking it off, or pull it down... it cant rememeber, you have to put pressure on it to hold it though.
Old 08-25-2004, 03:05 AM
oldschoolcivic's Avatar
oldschoolcivic oldschoolcivic is offline
Yeah pushing it up works but sometimes it wont. On my chevy i just torched it, your changing it anyways right.
Old 08-25-2004, 03:08 AM
Forunn Daberator
think hes just replacing the axel
Old 08-25-2004, 03:49 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
well you probly going to want to replace the ball joint but the easy way i did it with that same problem is take a impact gun and it well come off
Old 08-28-2004, 07:53 PM
Jos4DCivic's Avatar
damn still no luck. i put pressure on it but still wont budge.
91 Hatch SI
Finally painted!!!
