Old 08-24-2004, 03:17 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Angry Need help with my Blitz Dual Spec S
I just installed my Blitz Dual SBC Spec S that i got used for a good price. But I am running my stock bov . (i know i have to order a better bov). When i went out for a test drive i turned the boost controller off. Which means it should be running at around 7-10 psi right? (Because of the actuator spring)
Well this did not happen. It just kept going up to around 13 to 14 psi. So i dont know what the hell to do? Do you think the controller is messed up? or could i be something else? Please help.......
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 08-24-2004, 03:38 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Need help with my Blitz Dual Spec S
I have never seen a 2g run 7-10lbs of boost.
This seems normal to me.
Any 2g guys care to comment.
Kris
2012 Genesis Coupe 2.0t
Old 08-24-2004, 03:41 PM
Killa_DSM's Avatar
Oh so what is the stock actuator pressure?
Old 08-25-2004, 07:32 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Mine stock was about 12lbs. When I took out the BCS restrictor it jumped to about 13 or 14lbs.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-26-2004, 01:13 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Actuator is like 7-9, I forget. The BCS stock tries for 14, in my case it didn't. Yours sounds normal.
