Old 08-24-2004, 11:29 AM
riff22 riff22 is offline
bcs help!!!!!!
i have a stock 95 talon i put a air/fuel gauge in and was running normal. i did the bcs mod and now my gauge says im lean all the time. would that mod of caused it to run lean? is there a fix? or is this fine?
Old 08-24-2004, 01:04 PM
IhatetheHyena IhatetheHyena is offline
Well im not going to go into the detail of how much of a pos the A/F gauge is in off the shelf form but I can tell you why it would be running lean.
You removed a plug designed to restrict air flow.
Thus allowing more air flow, right?
Can you finish this sentence.
By placing more air into my motor my air fuel ratio will increace on the ___ side not the fuel side. ?????
Give it a shot.
Old 08-24-2004, 01:13 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: bcs help!!!!!!
Did you remember to plug the wiring harness back in?
I don't agree with you. As soon as the ECU sees more airflow it should adjust the fuel to compensate.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-24-2004, 01:34 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Re: bcs help!!!!!!
For Sale 98 Eclipse GS, 5 spd
Old 08-24-2004, 01:48 PM
Re: bcs help!!!!!!
Why is that weird? Is that incorrect?
1997 Spyder GS-T
5-Speed
Old 08-24-2004, 02:00 PM
ashah000's Avatar
Re: bcs help!!!!!!
LMFAO haha man it says werd not weird
Old 08-24-2004, 02:06 PM
spoolinscboy spoolinscboy is offline
Send a message via AIM to spoolinscboy
The BCS mod is a rather odd mod, because it is complicated and you could avoid problems by just getting a MBC between 60-100 bucks.
Old 08-24-2004, 02:28 PM
Re: bcs help!!!!!!
Wow....and all this time I thought it said weird. Oops!
1997 Spyder GS-T
5-Speed
Old 08-24-2004, 03:07 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: bcs help!!!!!!
the AF gauge reading doesn't become accurate untill the throttle opens up to a certain level.
06 Charger SRT-8 black.
Old 08-24-2004, 05:03 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: bcs help!!!!!!
What's so odd about it? It's not complicated at all, and it takes a total of 10 minutes to do. I do agree with you though, if you have the money it would be better to just buy a $50 MBC.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 08-25-2004, 11:51 AM
Re: bcs help!!!!!!
well i dont have the piece to put back in im not sure how accurate the gauge really is but i do know that when i used to floor it it would go to rich now it stays in lean like the first bar... is it drive able till i buy a MBC?
Old 08-25-2004, 11:53 AM
Re: bcs help!!!!!!
also my buddy told me my o2 sensor could be going bad. is this true? i thought it either worked or it didnt and the gauge wouldnt read anything
Old 08-25-2004, 01:33 PM
For all we know he can be running 18 psi on poor flowing injectors.
He basicly explained nothing to us. I took it for what it is.
Old 08-25-2004, 01:42 PM
it's not really odd, but it just makes more sense to just a MBC and go the correct and easier way.
Old 08-25-2004, 08:13 PM
Re: bcs help!!!!!!
im only running like 15 psi all stock ecept for the dump tube mod and the bcs
