Old 08-24-2004, 10:44 AM
ktbaby ktbaby is offline
Help 2000 GT hard to start & not keeping an idle.
Hi, could someone please help me.
I have a 2000 mustang gt. When I start it, it cranks up and immedialtely dies. I have been priming the fuel pump for a while and that has seemed to work getting it to start properly. And no problems dying when at an idle. But, now that isn't working. I can keep it running as long as I keep my foot on the accelerator. When first starting the car I have to torque brake it to keep it going. Then after driving on the highway it is fine ( no dying problems when I come to a stop). But, if I just drive it in town I dies when I come to a stop. Does anyone have any ideas on what to try? Any help would be greatly appreciated. Thanks.
Old 08-24-2004, 04:28 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
sounds like a bad idle air control motor. take it off and clean it out thorougly with carb cleaner. if that doesn't work, get a new one. they're less than 20 bucks. not sure where it's located in a newer stang, but i'm sure somebody here does.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 08-25-2004, 08:33 AM
brentmcq brentmcq is offline
Check every hose connection from you MAF sensor back to your throttle body. If your getting a leak anywhere along the path it will die immediately after starting it and won't hold an idle. My 2000 GT did exactly the same thing due to a hose just coming loose from my cold air intake.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 08-31-2004, 02:48 PM
Re: Help 2000 GT hard to start & not keeping an idle.
Hi,
Thank so much! It was the idle air control motor. But, it cost about $75 from the dealer. My husband installed it. Problem solved. I love the internet! Thanks again.
