Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-24-2004, 10:08 AM
drsmash drsmash is offline
94 starts then dies
starts well when cold, but after warming up it will take 3 to 4 starts and pushing the throttle down to start. after it starts it stays running just fine.
Old 10-21-2004, 08:44 PM
randy dodson randy dodson is offline
94 starts then dies when cold
my truck does the same thing,can anyone please help?
Old 10-21-2004, 10:54 PM
randy ,I replaced the fuel pump and that did for me
Old 10-28-2004, 02:20 AM
rollie1960 rollie1960 is offline
Re: 94 starts then dies
If problem keeps up check your fuel regulartor that's on the intake manifold read your Chiltons Manuel it will tell you where to locate it, check it with a light and mirror and see if it keeps dripping fuel after the Truck is shut down replace it or write me back for more HELP. Good luck! RS
Old 11-25-2004, 06:27 PM
strmn94's Avatar
strmn94 strmn94 is offline
here is something to try, it could also be a dirty fuel filter, and also the filters in the injectors may be dirty also. a friend with a van with the TBI, had the same problem and thought it could have been a vacuum leak, to a bad EGR valve, and even a bad fuel pump. turned out to be the filters in the injectors. when you remove the injectors from the TBI, there is a small screen, which is the filter. clean it with card cleaner or electrol sol spray and then reinstall the injectors adn that should take care of it.
