Old 08-24-2004, 01:34 AM
Ronwaz Ronwaz is offline
Speedo bouncing
I have a 99 Gt with a vortec supercharger, its an automatic,since i put the charger on I have had a few problems the latest is the speedo will bounce around and you can feel the trans shift slightly, I have had the speed sensor changed but that wasent it. any help would be helpful
Old 08-24-2004, 02:51 AM
xyfalconsrock's Avatar
xyfalconsrock xyfalconsrock is offline
Send a message via MSN to xyfalconsrock
Re: Speedo bouncing
The only time i've heard of a speedo bouncing is when you go faster than the speedo says.This guy i noe is very crazy and he did that.
Sorry if i am 0 help.
Old 08-24-2004, 06:19 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Speedo bouncing
You mean your speedo just kind of flops around all over the place under acceleration? Its probably a stripped speedo gear in the tranny.
1969 Cougar
357w & TKO - 475hp
Old 08-24-2004, 07:20 AM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
Do you have the 3:73 gears? I have yet to put in the Brothers speed calibrator with the stock gear. I have the aftermarket gear in there to compinsate and after about 3 months it gets chewed up and bounces all the time. Change the gear first, then get the calibrator.
Old 08-25-2004, 11:52 AM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
yeah i have the same problem my spedo gear was chewd up to but i have not gotten a new one yet. where is a good place to buy those
Old 08-25-2004, 05:54 PM
mustang2422 mustang2422 is offline
Re: Speedo bouncing
I used to have a 91 with a speedo that bounced. On mine the problem was a dry speedo cable. I pulled the intsterment cluster out and sprayed wd40 down the exposed end of the cable. So far its work for 4 years.
