91 SE - stalling, no power - RESOLVED!
FInally (I hope) my problem is resolved.
First, 91 SE, manual transmission, 230K km. The car would suddenly have no power while driving. Later, I narrowed it down to a (usually) warm engine, pushing hard with a load (like running up a hill), and when letting the rpms drop to between 1500 and 3000. It would sometimes idle roughly. If I stopped and waited about 5 minutes, the engine would 'catch it's breath' and I could run it all day without problems.
Checked: EGR, no effect. Had Nissan dealer check computer codes - he said there were none, and was convinced that the problem was MAF. I cleaned up connections to MAF with contact cleaner and toothbrush, cleaned up ground connection to engine block, fixed a loose vaccum hose connection - no effect.
Checked computer - had code 33 (!). Followed Haynes manual instructions, disconnected the O2 sensor (what a pain in the arm that was!), and the car ran fine. Reconnected, the car ran like a pig.
Took it to Nissan - the checked out the O2 sensor, and replaced it. The car is great again!
Thanks to everyone here (and other boards) that helped me understand and resolve the problem.
Michael
