Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 08-24-2004, 12:25 AM
RX7gen2 RX7gen2 is offline
Clutch Problems? Please Help!!!
Hi all RX7 fans and tech guru's! I hope someone on here can help with a problem that I have with my 1987 RX7 5 speed. I was driving through my neighborhood a few days ago and all of a sudden I had no clutch! I can push it right to the floor and nothing! Cant get it into gear! I looked under the hood and noticed that the fluid in the resovoir was half full. I added more and still nothing. I was told that it may be the clutch master cylinder or the clutch, well no kidding but I would like to know from someone out there if this has happend to you? Is there a way of telling for sure if the clutch is gone? Is there a way to tell if it is a hydraulic problem? Before I have the car towed to the nearest Mazda dealer I need input from fellow RX7 owners. Thanks to all!
Old 08-24-2004, 04:38 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: Clutch Problems? Please Help!!!
Oh man, this has happened to me a few times. Its probably either your master or slave cylinder. Our clutch hydraulics are notoriously prone to failure.
1988 10th AE Edition TII
More mods then you have.
Old 08-24-2004, 03:30 PM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
Yes I has to be you master or slave cylinder , It happen to me before too..
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 08-24-2004, 05:34 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
our clutches just suck in general haha
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 08-25-2004, 09:31 AM
Thanks to all for the info. I will now search for the part and try to do this myself. The dealer wants about $600 for this job. It would have been cheaper to install a new clutch! Wish me luck guys!
Old 09-03-2004, 11:02 AM
rotaryismychoice rotaryismychoice is offline
Send a message via AIM to rotaryismychoice
you can get a clutch slave rebuild kit from places like autozone or even discount aut parts. it's VERY inexpensive and it's not a tuff task. if it is indeed the slave, then when you take it apart there will be fluid past the rubber grommet in the slave and the grommet will be pretty well fouled. after replacing all the internals of the slave with the rebuild kit, and if it still doesn't work, you may have some investigating to do on the clutch unit as a whole. wheather it may be the pressure plate and t/o bearing or the disk itself. either way, its not a terrible situation, i got a new 4 puck race disk for my centerforce DF and rebuilt the slave for under 115 bucks, but i also did all the work my self. repair the slave and then go from there. good luck.
