Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-23-2004, 09:41 PM
seahawk98 seahawk98 is offline
2001 Camry CD_player in a 98 Camry
Hi, Can I fit a 2001 cd_player in a 98? If it can be done will all the plugs in the back of the radio be the same as the 98?
Regards,
Seahawk
Old 08-24-2004, 06:43 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: 2001 Camry CD_player in a 98 Camry
The plugs are identical...you will have no problems with fitment whatsoever.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 08-24-2004, 03:38 PM
Re: Re: 2001 Camry CD_player in a 98 Camry
Hi, yotatechie04
Thanks a lot, now I will get a 2001 CD player from EBay for my 98 camry. Helpfully it will read CDR music cds; cause the one I got with the 98 won't read CDR most of the time.
Regards,
Seahawk
Old 08-24-2004, 05:09 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
seahawk98,
We have the 3-in-1 radio (radio, CD and cassette all in one double-din unit) in our 98 XLE. It plays all of our cdr's. We also have an aftermarket Panasonic 8 disc changer mounted in the trunk that is controled by the factory radio and it too plays all of our cdr's. You might want to try one of those lens cleaning things on your factory radio first.
Good luck.
Mike
Old 08-24-2004, 07:55 PM
You could clean it, but if you do decide to replace it, you should try and burn your CDs at a lower speed for better quality to avoid future difficulty.
Old 08-24-2004, 10:37 PM
Originally Posted by Mike Gerber
seahawk98,
Good luck.
Mike
Hi, Mike
I got the factory in dash 3 disc changer (Toyota L4210 CD player), for some reason it plays all other normal CDs fine excepts when it comes to CDRs. I believe the lens is clean; otherwise it would not be able to play any CDs at all I think. I have tried burning it at 4x, 8x, and 24x with no success of playing it with the Toyota L4210 CD player.
Regards,
Seahawk
Old 08-25-2004, 08:03 PM
AF -Advisor
seahawk98,
I have the L4200 3-disc changer in my 94 Camry. It too plays all of my cdr's. I think the L4200 is just an older version of the one you have. There is definitely something wrong with your unit. Again, try cleaning the lens. By the way, I believe these units were actually made for Toyota by Alpine. They use a standard Alpine 3 disc magazine. I just thought I would mention the fact they are Alpine units just in case you need to get it repaired at some place.
I would also suggest you try your cdr's in a friend's car and also try some of that friend's cdr's in your car's player. That way you can pinpoint whether it's your car's player or the way your cdr's are being burned that is causing the problem.
Mike
Old 08-26-2004, 03:41 PM
seahawk98,
Mike
Hi Mike,
Thanks for the information. Can you please tell me what is the brand and model of the CDRs that you use to burn your CDs? And what type of software you use to burn them on your PC. Hopefully I can get it to work since it's working for you.
Regards,
Seahawk
Old 08-26-2004, 04:52 PM
AF -Advisor
seahawk98,
I have been burning cd's for about 5-6 years. I have several hundred of them. I have mostly used Verbatum cdr's but have also used Memorex and Samsung. I have rarely, if ever, had any problems with any of them. I am currently using Easy CD Creator version 4.0 but have used older versions of Easy CD Creator. My first burner, years ago, came with NTI CD-Maker. All have worked equally well. Since I have been burning cd's for a long time, I started to burn back then at speeds of 2X or 4X. I rarely burn at speeds higher than that today. If I have plenty of time I still burn at 2X. I would suggest you try to burn one cdr at 2X and see if it plays in your car.
Good luck.
Mike
Old 09-10-2004, 08:12 PM
AF -Advisor
seahawk98,
Any progress in determining what the problem is?
Mike
Old 09-12-2004, 08:17 PM
seahawk98,
Mike
Hi Mike,
No luck yet. Still can't get my Toyota cd player to read CDRs. Whish I know what the problem is.
Regards,
seahawk98
Old 09-14-2004, 03:12 PM
AF -Advisor
seahawk98,
Have you tried a CDR burned by someone else (not burned by your computer using your current software) in your car's player? That will tell you whether it's the player or you computer (or software) that is causing the problem.
Mike
Old 09-14-2004, 09:42 PM
seahawk98,
Mike
Hi Mike,
Yes, I have try all different types of CDRs my self and from other people. None of it seems to work.
Regards,
seahawk
Old 09-14-2004, 11:32 PM
nipsirc nipsirc is offline
You must be burning either mp3's or the wav format in which only one of either format, your cd player does not recognized. Check your player and see if it read's mp3's.
