Old 08-23-2004, 08:26 PM
sculldan sculldan is offline
Send a message via AIM to sculldan
96 blazer tire on the lean
i have a 96 blazer with a 2 inch suspension and 2 inch body lift... i got into a car accident and ever since the guy hit me my driver side front tire is leaning bottom out really bad... i replaced the upper control arm and it took care of some of the problem any i deas what it could be...
33 12.5 15 superswampers
superlift 2 inch suspension
also any ideas about switchin out the independent front for a solid axle???
Old 08-23-2004, 10:35 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: 96 blazer tire on the lean
Might be a tie rod, or i forget the component that takes care of camber. Get it checked out. He hit you he has to fix it.
Old 08-24-2004, 02:21 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Take it to an alignment shop and get a proper computer alignment.
Old 08-24-2004, 08:24 PM
his insurane is refusing to pay for the damage saying i did it offroading all i got money for was body work and i put it into the suspension... a friend of mine said it could be the hub assembly either way ill get it aligned tomorrow and hopeuflly it works if not ill be back on here...
thanks for the posts
Old 08-30-2004, 09:58 PM
well i needed a whole new front end so 180 bucks later the prob is fixed...
