Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-06-2002, 02:20 PM
blackma blackma is offline
Post 1997 Sentra won't start
My daughter has a 1997 Sentra GXE that has 60,000 miles on it. It will not start now. It has spark, timing looks ok, getting fuel, turns over fine, and has compression. Does anyone know what it could be? I am at my wits end and the nearest Nissan mechanic is 60 miles away. I have never seen anything quite like this.
Old 02-08-2002, 03:59 PM
SentraFi's Avatar
SentraFi SentraFi is offline
Try asking your question on:
http://www.b15sentra.net/vbb/forumdi...?s=&forumid=36
Good Luck.
Old 06-09-2004, 04:09 PM
Jesser Jesser is offline
Re: 1997 Sentra won't start
Possible problems: idle motor, air flow valves and sensors, sludge component... For two years my 97 sentra on a daily basis would either not turn over, or it would turn over but stall as soon as I let go of the key. The check engine light will not come on for this because the computer does not recognize the faulty parts as causing a misfire. One of the wires to the idle motor was not connected, which caused the car to stall a lot (at stop signs & lights, or if I was moving too slowly). The air flow control sensor and valve were bad which was the reason the car would not start or not stay running. Since I had these problems corrected the car has not stalled once, and it fires up every time I turn the key. As far as the sludge component, it's not a major problem, but it wouldn't hurt to have it cleaned. I noticed that after having it cleaned the car seemed to run a lot smoother. Hope this helps!
Old 06-30-2004, 01:21 PM
habenero2002 habenero2002 is offline
Send a message via Yahoo to habenero2002
cam or crank sensor
Old 07-10-2004, 06:37 PM
navy001 navy001 is offline
Clean Your Idle Control Vlv And Check Pvc
Old 07-12-2004, 05:54 AM
Force Recon Force Recon is offline
does the car have any kind of amp for a stereo system? Cause when I hooked mine up, the ground wasn't in tight and the amp started sucking so much juice from the battery that my car wouldn't start or it would start and then die.
Old 12-02-2004, 05:07 PM
masangya masangya is offline
Question idle air control valve / aux air control
i have a 97 nissan sentra gxe with a check engine light on fault code 0205 iacv/aac . i removed the iacv harness with engine running and idle does not decrease . the iacv reads 180 ohms when the engine is off and part is off of the intake it should be around 50 -100 ohms . wondering if anybody came across the same problem. the part cost $ 180 i just want to make sure before i purchase this part . the car dies when it is in reverse intermittently. haynes repair manual says to replace the iacv/aac .
Old 12-13-2004, 07:09 PM
iorn eagle's Avatar
iorn eagle iorn eagle is offline
Send a message via AIM to iorn eagle
if i don`t crack mine up in a while mine don`t start. also go to www.sentra.net.
1964 ford falcon 2dr hardtop. 200 inline 6
2003 sporttrac xlt gold 260whp. xcal tune,intake,spacer, and full exhaust system
2008 nissan altima sl bought may 28,2008
gone but not forgotten,
2004 buick rendezvous cx traded.
1997 nissan sentra gxe rip
1998 ford contur se sport
1992 ford excort lx hatchback
1980 chevy scottsdale 350,585 cranck hp
1987 isuzu pup
1964 vw bug
Old 12-16-2004, 01:45 PM
Creagach Creagach is offline
Re: Re: 1997 Sentra won't start
Originally Posted by habenero2002
cam or crank sensor
power transistor has to see a reference from the cam angle sensor in order to get spark at the coil.
