Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 08-23-2004, 07:38 PM
jit mcguillicutty jit mcguillicutty is offline
Starter Problems?
My starter will not turn off even if my ignition is turned off. I had to disconnect my battery to turn off the starter. Is this a starter problem or something else like ignition.
Old 09-17-2004, 11:09 PM
xtoyotacorex xtoyotacorex is offline
Re: Starter Problems?
Your starter pinion is sticking. Remove the starter and look at it, also check your flywheel teeth, they might be broken, most likely youll have to buy a new starter. good luck!
