Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-23-2004, 07:31 PM
jt_crx jt_crx is offline
Help! o2 sensor problem
i have a crx with a b16a. it has two o2 sensors on it. i recently put on a hi-flow cat and a header, and there is only one bung for an o2 sensor. can i just get a 4 wire sensor, if so which o2 sensor plug would i use.
Old 08-25-2004, 08:20 PM
civicwala civicwala is offline
Send a message via MSN to civicwala Send a message via Yahoo to civicwala
Re: Help! o2 sensor problem
one option is, take both of ur o2 sensor wires and put em in one sensor, this is the cheapest way and works fine, atleast it did for me
Old 08-26-2004, 12:32 AM
hundahunta hundahunta is offline
just install the o2 sensor in after the cat. you need to drill and weld it.
Old 08-26-2004, 01:33 PM
Re: Re: Help! o2 sensor problem
i got to buy 2 new 02 sensors, will they be long enough to reach? they plug in the front below the valve cover.
and where exactly would i install the other sensor. would it be on the end of the cat or on the pipe after the cat?
and also, are the 02 sensors the same. what would i ask for when i go buy them?
Old 08-26-2004, 11:58 PM
Re: Re: Re: Help! o2 sensor problem
one o2 sensor plugs into the exhaust manifold just befor the cat, the other needs to be installed right after the cat.. what year is that vehicle!! Is the wiring harness/connector on the engine 4 wire or 2 wire.
I don't really know if the 2 are the same I suppose so. The main o2 sensor is the one on the exhaust manifold the other o2 after the cat is to monitor the cat converter for efficiency. that's all it does. The difference between a 2 wire and 4 wire sensor is that the 4 wire o2 sensor has a heater inside of it to allow the o2 sensor to reach operating temperature faster to allow the vehicle to enter closed loop sooner to reduce emissions during cold start up and longs periods of idling....
Old 09-02-2004, 08:33 PM
swiftrecon swiftrecon is offline
Re: Re: Re: Re: Help! o2 sensor problem
YEAH. WHAT HE SAID!
