P0705- Transmission Range Sensor Circuit malfunction (PRNDL Input) ??
What will cause this code?? I just recently did a engine swap and this code came up. the car shifts fine but everytime i clear the code it snaps back on...???? will the shifter linkage not being adjusted right cause it??? thanks Greg
Re: P0705- Transmission Range Sensor Circuit malfunction (PRNDL Input) ??
Try this, I don't know if it's what you want, but, maybe
http://www.autobook.co.kr/theory_pra...ta_example.htm |
So since my car does not show the position on the instrument cluster (gauges dont support it CAR~96se Motor is a 98 gt), I can just have the dtc shut off during pcm programming??? of is there a problem? I am lost on this one... thanks for the help... Greg
I would check the neutral safety switch. It's located on the shift shaft of the trans, and is a common problem. Also check the wiring leading to the switch, as it is exposed to road grime and has been known to corrode and melt.
I have the same problem on my 04 Grand Am, you may need to replace your transmission range switch also known as the park/neutral switch, they are known for going bad. It basically tells the PCM which gear the transmission is in. Depending on the application, they may cost up to $100 and you need to special order it through a GM dealer
Sorry but please check the date and do not resurrect old threads per AF and our forum guidelines. See link below. This thread is closed. Click here
