Old 08-23-2004, 06:41 PM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
Does an 89 F 250 have some sort of idle recovery when you left off of the gas.
I have an 89 Ford pick up with a 351 and it dies when i let off of the gas. It seems like it just won't hold idle. I'm not familiar with fords at all so if someone could help me out, i'd greatly appeciate it. Thanks a bunch.
Jake
Old 08-23-2004, 10:08 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Does an 89 F 250 have some sort of idle recovery when you left off of the gas.
Could very well be a bad TPS or IAC. More than likely its the IAC (Idle Air Control). Its located on the side of your throttle body, have a plug in one end and 2 bolt I think holding it on. Shaped like a cylinder. Good luck with it.
1969 Cougar
357w & TKO - 475hp
Old 08-25-2004, 05:47 PM
thanks what i figured it was, but unfortunately, I can't get the screws out. I'm going to try a little hand help impact screw driver and see if i have any luck with that. bah.
thanks for the help
Jake
Old 08-30-2004, 07:43 PM
Paul Masley Paul Masley is offline
If you use a cold chisel, you can spin the screws out. Don't cut the heads off as you will need to reuse the screws. Also, while you are there, clean the throttle body out. Only use Mineral Spirits or turpintine. Do not use any hot paint thinners or carb cleaners. The interior has a special coating and you do not want to disturb it.
Everybody is an idiot (including me) some of the time, but there are others that make a full time job out of it!!!!!
