Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-23-2004, 06:07 PM
Katakizm Katakizm is offline
Arrow Two Questions
First question.... When i start up my 94 T-bird and take off... if i leave it in 1st and try running it past 3 grand it seems to have a govner that kicks in... but once it warms up its not a problem... any ideas on why?
Second... i've got a deck just sitting at my house and i still can't figure out how to take out the factory deck... all i can find is 4 little holes... HELP!
Old 08-23-2004, 09:22 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Two Questions
dunno bout the transmission. Might just need to warm up...
as for the deck, you'll need to remove the plastic dashboard piece (normally black, or dark blue, or dark green..depends on exterior color) that covers the gauge cluseter. Then you can rmove the black (or what ever) plastic cover that covers HVAC, and reciver, clock etc. The unit should be in a metal casing attached to the plastic cover. Un-do 2 wiring harnesses for the reciever.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-23-2004, 09:31 PM
lightin rod lightin rod is offline
Send a message via MSN to lightin rod
Re: Two Questions
i have a 94 tbird that does the same thing the problem is not in the transmission its somwhere in the emmisions when the car is cold the computer thinks its warm and leans out the fuel mix i havnt figured out what part it is yet
Old 08-23-2004, 10:46 PM
emailer33 emailer33 is offline
Send a message via AIM to emailer33
Re: Re: Two Questions
woah woah woah, this is not right. the four holes are meant for the ford radio removal tool. they're just two simple horseshaped pieces of metal, you can get them at your local autozone or any auto parts store. you just slide them in until you hear it locks in place, then you pull outward from both sides, so the left one you pull left, right w/ the right, and pulling it outward at you at the same time. you don't need to take off everything since the radio slides right out.
Old 08-24-2004, 02:29 PM
tbird92 tbird92 is offline
I used a wire hanger cut into 2 'U' shapes........... it took a while but was free........ that was on an 2002 Escape radio but its the same anti-theft thing.......
Old 08-24-2004, 08:03 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Two Questions
I believe I would spend the $4 for the tools from autozone.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-24-2004, 08:45 PM
Re: Two Questions
Hey thanks guys i actually found out how to fix it later that day... its the stalling i cant figure out..
