Old 08-23-2004, 02:56 PM
eclipsefan98 eclipsefan98 is offline
Send a message via AIM to eclipsefan98
Best Exhaust...?
I was wondering what the best sounding exhaust is for my 2.0 talon. i was thinking about the Apexi N1, but i want something that kinda rumbles at idel and then gets loud at higher RPM. i definately dont want a little ricer fart can or something that sounds like a souped up lawnb mower. i just want the best performace gains with a nice deep sound. thanks everyone!
-1996 Eagle Talon
CAI, reprogramed ECU, NGK plugs, and ported head
-1972 Malibu
Mods: 409ci small block replaced the 6 cyl., posi. rear end, low gear ratios, TH350 trans., high comp. pistons, mild cam, no a/c, heater
Old 08-23-2004, 02:57 PM
Re: Best Exhaust...?
oh ya i almost forgot, i will be getting headers and a cold air intake along with this exhaust.
-1996 Eagle Talon
-1972 Malibu
Old 08-23-2004, 03:31 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Greddy evo 2 IMO
For Sale 98 Eclipse GS, 5 spd
Old 08-23-2004, 04:58 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
i have the APEXI n1 and it sounds pretty good,its not as loud as the veilside i had on their befor.i still think the HKS hi-power sounds the best!
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 08-23-2004, 07:00 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
magnaflow sounds the best (deep and throaty) , dont know about how it performs...
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-23-2004, 08:05 PM
coolguycooz coolguycooz is offline
Magnaflow does sound the best only if your car is fully warmed up it sounds hella awesome below 4000 rpms after that it turns to rice unless your car is warmed up then it sounds hella tight since your getting headers and a cold air intake magnaflow sill sound hella nice in your car.
Old 08-23-2004, 08:38 PM
george536's Avatar
george536 george536 is offline
magnaflow +1
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 08-23-2004, 08:40 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i liked my RS*R exhaust ,but they only make it for AWD cars
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
