Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-23-2004, 01:33 PM
98whitegpgt 98whitegpgt is offline
Send a message via AIM to 98whitegpgt
93 dakota wont start
i have a problem, i have a 93 dakota 5.2 318, my winter truck. i went out to run it a little bit today and it wont start. it cranks very strong, but it wont start up. i need some help please!!!!!
Old 08-23-2004, 01:42 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 93 dakota wont start
Is there gas in it?
My Mopars
Old 08-23-2004, 01:51 PM
ha yea i just put about 3 gallons in and tried to start it again, pumping the gas
Old 08-23-2004, 02:20 PM
BleedDodge's Avatar
Pumping won't do anything. It's fuel injected.
Is the check engine light on?
Did you check for spark?
My Mopars
Old 08-23-2004, 03:25 PM
no check engine light, and there is no spark, now what?
Old 08-23-2004, 06:25 PM
BleedDodge's Avatar
Are you sure? Did you pull one of the plugs to see for sure if there is actually no spark? If not, the coil might be bad, or even a fuse could be blown or something.
This is your winter truck, right? I'm guessing you had it in storage or something eh? Mice could have eaten through a bunch of important wires...
My Mopars
Old 08-23-2004, 07:30 PM
yea me and my dad tested it and there is no spark. it was parked outside. it was started about every week or so until it stopped starting about 2 weeks ago. ill check the fuse, and we tested the coil also, it is good. ill check the fuses. could it be the computer, cause that went at about 60000 and it did the same thing?
Old 08-23-2004, 11:52 PM
BleedDodge's Avatar
Might be. The distributor pickup might be bad. Can you tell if power is making it as far as the distributor?
My Mopars
Old 08-24-2004, 08:40 PM
tans tans is offline
If you don't have any fire at the coil it will probably be the comp board. I just had to replace mine in my 93 5.2,but I have got almost 130,000 on it. Good luck!
Old 08-24-2004, 11:07 PM
there is no voltage getting to the coil
Old 08-24-2004, 11:18 PM
BleedDodge's Avatar
Computer.
My Mopars
Old 08-24-2004, 11:30 PM
whats the cheapest place to get a computer
Old 08-25-2004, 01:35 PM
Shayne225 Shayne225 is offline
Is there any way to remove Testors glue?
Old 10-17-2004, 04:53 PM
slidman slidman is offline
I'm having the same problem with my 95. Sat for weeks when I went to start it. It just turned over like it wasn't getting a fire . Did all of the above and it still will not start. If its the computer. Are you talking about the one on fender. I think they call it SBCM. Need help this is my winter truck.l
Old 10-17-2004, 08:19 PM
this is my winter truck too!!!! need it soon, wheres a good place to get a computer
