Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-23-2004, 10:22 AM
humanpixel humanpixel is offline
Question 99 Integra AC not working...
Hi,
My wife owns a 99 integra and the AC recently gave out. When I say gave out I mean it still blows air but it's no longer cold. I live in Texas where it's very hot, so a working air conditioner is a must. I took the car to a Jiffy Lube thinking it might just be low on freon. The technician there said he flushed and refilled the system 3 times and couldn't get it to blow cold air. He also said that the air conditioner "motor" was not kicking in when it should be. He said you should be able to hear it kick in when you turn on the A/C system.
I'm not really sure what to do at this point. I'm going to take it into another mechanic, but I don't want to spend $1,000 to replace the air system. Is there any information that an Integra pro can arm me with before I go to the mechanic so that I will know if he's trying to con me.
I have read that sometimes the drive belt can come lose and cause the AC to stop working. However, I don't know if "stop working" means no air at all or just no cold air but still some air flow? Any help will be apprecaited.
thanks...
Old 08-23-2004, 03:50 PM
eclipse2quick21 eclipse2quick21 is offline
Re: 99 Integra AC not working...
Originally Posted by humanpixel
Hi,
thanks...
well, i have the same problem. but my compressor went out so i have to replace the whole system. if thats your case, get ready to spend around 800-1000.
Old 08-23-2004, 04:41 PM
tsugsr tsugsr is offline
What part of texas do you live in? if you are anywhere by chance near fort worth i can recomend you to one of the best honda/acura mechanics around there. check the tension on the belt and make sure the belt is not loose or torn, thats the simple thing you can do. Next get a leak test on the system, they will put dye in the freon to see if its leaking, hopefully its just a small leak that can be fixed, if that seems fine it could be your compressor, which as stated above, can cost about 1K.
Old 06-14-2005, 02:46 PM
stopufool's Avatar
stopufool stopufool is offline
look on ebay you can fine rebuilt ac compressors for about 200, they work pretty good, look just like new
Old 06-14-2005, 02:51 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Re: 99 Integra AC not working...
Hey I live in Grand Prairie you know any good tuners or anything performance related around?
